Turn signal/Hazards problem!! - JeepForum.com
post #1 of 6 Old 01-20-2014, 02:04 PM Thread Starter
ButtDyno
Hey all,
It's my first post here, and I got a doosie...I did mucho searching and found only comments on replacing /repairing flasher relay located behind knee bolster. Well I played the game and replaced it and I still have my problem.
PROBLEM: Turn signal engaged to right works great no problem, LEFT turn signal engaged the front blinks correct BUT both rears are flashing...no bueno
Please tell me where to start...I have a test light /voltmeter and some mechanical background. HELP
Thanks-
ps...I really like all the info here and hope to learn more.
ButtDyno is offline
post #2 of 6 Old 01-20-2014, 03:23 PM
AZ Jeff
2014 JK Wrangler
When you engage the left turn signal, you get the left front to flash, but BOTH rear signal bulbs flash. Is that correct?
If so, its almost certainly your "multifunction switch", which is what controls both the turn signals and 4-way flasher. My description above is a common failure mode. A new switch should fix the issue.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 6 Old 01-20-2014, 04:01 PM Thread Starter
ButtDyno
Yes that's exactly what happens...left signal up front and both rear blinkers are flashing...but when I do right everything is good no double rear flashing.
ButtDyno is offline
post #4 of 6 Old 01-20-2014, 04:03 PM Thread Starter
ButtDyno
So would this be a sufficient replacement or should I go to NaPA? http://www.oreillyauto.com/site/c/de...2100&ppt=C0039
Thanks by the way AZ Jeff I really appreciate it.
ButtDyno is offline
post #5 of 6 Old 01-21-2014, 10:02 AM Thread Starter
ButtDyno
Update: Went to Napa spent $45 and now my signals work perfect. You AZ Jeff are the man...Thanks soooo much sir. Dang...it's awesome to finally be on a forum that has awesome members and info.
ButtDyno is offline
post #6 of 6 Old 01-23-2014, 07:10 PM
AZ Jeff
2014 JK Wrangler
Glad I could help.
AZ-Jeff
AZ Jeff is offline
