turn of antenna motor, but leave antenna up? - JeepForum.com
post #1 of 12 Old 03-18-2007, 09:32 PM Thread Starter
XmuthJ
turn off antenna motor, but leave antenna up?
hey my motor is being really annoying lately. sometimes the motor stays on even after it pushes the antenna up or down, so I want to figure out how to turn off the motor and leave the antenna up, so that's it's permanently up.
is there a seperate fuse in fusebox for the motor or is there another method?
|___NEW JEEP___| 87 MJ Lwb | 4.0L | ba10 | D30/D35 | NP231 |______________|
^*^*^ Waiting to go in: 94 YJ AX-15, 99 XJ NP231 (23 spline) ^*^*^
Originally Posted by FrumpD63
Had I bought that lil mazda I was looking at, they wouldnt have found my body until the spring.
XmuthJ is offline
post #2 of 12 Old 03-18-2007, 09:33 PM
alexrule123
alexrule123's Avatar
your antenna goes up and down? mine is just a removable one
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #3 of 12 Old 03-18-2007, 09:36 PM Thread Starter
XmuthJ
yeah it's annoying as hell. and really loud. My XJ is the only one i've noticed with it. All the others have a solid one.
XmuthJ is offline
post #4 of 12 Old 03-18-2007, 09:40 PM
JoeShmoXJ
JoeShmoXJ's Avatar
1989 XJ Cherokee
Mine has it too, except it is now stuck in the down position (thank god,i dont use it anyway and the grinding sound was pissing me off). I think your best bet would be to disconnect the power for the antenna (not the signal wire) just above the passenger side kickpanel. Once it is in the up position and you pull the power, it should have no way to move. (if you pull the signal wire its just gonna go back down).
1989 XJ
4.0 / AW4 / 242 / RE 5.5"
30 Front: Chromo Shafts/Joints/4.88's.
44 Rear: Aussie/Crown Vic Disks/4.88's
JoeShmoXJ is offline
post #5 of 12 Old 03-18-2007, 09:42 PM Thread Starter
XmuthJ
ill try that tomorrow...
XmuthJ is offline
post #6 of 12 Old 03-18-2007, 09:49 PM
94XJMadness
94XJMadness's Avatar
I never knew XJs had those up and down antennas
[_] ||||||| [_]
94XJMadness is offline
post #7 of 12 Old 03-18-2007, 09:50 PM Thread Starter
XmuthJ
Ya i'm guessing that it came on earlier models with the Accusound by Jensen package.
XmuthJ is offline
post #8 of 12 Old 03-18-2007, 09:53 PM
cmotsvt
Yep, my '88 had the sound package and power antenna.
Id just disconnect the pigtail at the motor.
cmotsvt is offline
post #9 of 12 Old 03-18-2007, 10:15 PM Thread Starter
XmuthJ
where and what is the pigtail?
and where is the motor at?
XmuthJ is offline
post #10 of 12 Old 03-18-2007, 10:24 PM
chance_p
2008 WK
Pigtail is the plug that the positive/ground wire go into. The motor is located inside of the passenger fender. Basically right behind the "Cherokee" emblem. You have to pull back the splash gaurd in the wheelwell then just look back there and you will see the motor.
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is online now
post #11 of 12 Old 03-18-2007, 11:05 PM Thread Starter
XmuthJ
thanks!!!!!
XmuthJ is offline
post #12 of 12 Old 03-27-2007, 02:55 PM Thread Starter
XmuthJ
Resolved!
Pulled back the splash guard and found the motor. There are three wires. Green, white and greyish. I cut the green one and problem sloved, it was defusing a bomb....
XmuthJ is offline
help with antenna lk123 XJ Cherokee Technical Forum 0 09-17-2009 01:20 PM
Which Antenna? laxsmith23 XJ Cherokee Technical Forum 9 11-04-2008 07:10 PM
CB antenna Kieffer87 XJ Cherokee Technical Forum 39 01-13-2008 10:59 PM
CB Antenna MSHarnett XJ Cherokee Technical Forum 5 03-09-2003 12:22 PM
Need antenna.... En4cer71 XJ Cherokee Technical Forum 2 08-07-2002 08:44 PM
