turbo in an xj? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > turbo in an xj?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 01-26-2008, 06:28 AM   #1
LeeBee
turbo in an xj?
Has anyone turboed an xj? If so ,what other mods/upgrades had(have) to be done to adapt to the HP boost? Like..axle ,tranny drive lines,ect. Lets hear the stories!!
"Practice technique my friend, and speed will come."
LeeBee is offline   Reply With Quote
Unread 01-26-2008, 06:47 AM   #2
longducdong
i haven't tubo'd an xj, but i have turbo'd a few other cars. i know you'd need to control fuel and timing, so i would recommend a nice standalone engine management. the list would go on and on. alot of stuff you don't NEED and i've seen some cheap turbo setup ups, but why cheap out on a turbo setup when you want it to make power. you'll need injectors, fuel pump, exhaust, ic, and spare parts, cause depending how you drive you'll be replacing alot of parts.
i have a ~400whp vw corrado
longducdong is offline   Reply With Quote
Unread 01-26-2008, 09:07 AM   #3
tdogg55555
I would go to the street forum and try that ?, you might get better results.
96 Country...Weekend warrior
tdogg55555 is offline   Reply With Quote
Unread 01-26-2008, 10:41 AM   #4
captain_ruggy
1994 XJ Cherokee
A trail ridden XJ has no use for a turbo.
1994 Jeep Cherokee 4x4
4.0 HO, Auto, 4dr., NP231, 8.25 rear
6 inches of bastard pack lift, 35/12.5/R15's
Aux. fan switch, homemade BPE's
moved intake, OEM towhooks
Rear disc brakes, JKS disco's
captain_ruggy is offline   Reply With Quote
  • turbo xj? - Cherokee Technical Forum (5 replies)
  • Turbo?? - Cherokee Technical Forum (3 replies)
  • 2.5 Turbo - Comanche Technical Forum (19 replies)
  • 4.0 Turbo, anyone? - Cherokee Technical Forum (10 replies)
  • turbo!? - Cherokee Technical Forum (30 replies)
