TUPY 0331 head - JeepForum.com
post #1 of 19 Old 02-22-2010, 07:18 PM Thread Starter
bmac13sv
TUPY 0331 head
Has anyone found/have any pictures of the word TUPY on their 0331 cylinder head? I wanna see what it looks like so i can identify one when i look for my replacement for my cracked 0331. THANKS!!!
Jeep XJ. 3.5" Full spring pack Rusty's suspension. aFe cold air intake. 33x12.5x15" BFG TA KO's on Cragar Soft 8's. 60mm TB. JCR Offroad Stage 3 Front and Rear Bumpers. New 4.0L (victim of 0331 head). aFe cold air intake. Dynomax Catback.
BUILD THREAD: http://www.jeepforum.com/forum/f177/bmacs-2000-xj-build-1292498/
bmac13sv is offline
post #2 of 19 Old 02-22-2010, 07:21 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
My understanding is that 2003 and newer are TUPY. I've heard that the stamping is somewhere around cylinders 3 and 4 but that is not confirmed. Maybe somebody with actual knowledge of TUPY will chime in.
Also, I would like to know where Jeep sourced the TUPY head from??
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 19 Old 03-02-2010, 06:37 PM
26679cj5
i would really like to see a pic also. i bought a 2000 tj a couple weeks ago and it turns out to have a cracked head and i would really like to see what i should be looking for while searching for another head.
26679cj5 is offline
post #4 of 19 Old 03-02-2010, 07:15 PM Thread Starter
bmac13sv
hey I just got done replacing my head yesterday. i didnt eve look for a junkyard head just bought it from here:
NEW JEEP/CHEROKEE/LAREDO 4.0/0331 CYLINDER HEAD : eBay Motors (item 160359021523 end time Mar-27-10 08:49:00 PDT)
has a 2 year unlimited mile warranty, is BRAND new, and they got it to me in 3 days.....free shipping too. i looked everywhere and called all around the US.
the job was not bad at all, hardest part were the underside exhaust/intake manifold bolts.
if you do get that head there is a hole that needs to be plugged, pm me if you want more details!
bmac13sv is offline
post #5 of 19 Old 09-03-2013, 06:42 PM
Dargon
Just saw a pic on another sight of a "Tupy" head. Could not capture the image for this sight (smartphone's are very limited.)
But it can be seen once the oil fill cap is removed. It is directly below the oil fill cap on the cylinder head.
I hope this help's some people,I too am facing the very same problem trying to find a good replacement head for my own XJ.
Dargon is offline
post #6 of 19 Old 09-03-2013, 06:45 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Like this:
CJ7-Tim is offline
post #7 of 19 Old 09-03-2013, 06:59 PM
RockRodHooligan
RockRodHooligan's Avatar
Originally Posted by CJ7-Tim View Post
Like this:
Hey, I took that pic!
0331 head TUPY revision
http://www.jeepforum.com/forum/f22/p...ml#post9187589
It's between the #3 and 4 exhaust rocker bosses
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #8 of 19 Old 09-03-2013, 08:42 PM
cbenez1
Hey Rockrod, I just checked my 01 and found nothing. So I assume they either have a TUPY or no mark at all ? No mark being the preferred result.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #9 of 19 Old 09-03-2013, 08:46 PM
RockRodHooligan
XJs never got the TUPY head from the factory, it didn't come along till 02 or 03 and can only be found in the newer WJ/TJs. You want the TUPY mark, that is the designation of being a revised head casting to correct the cracking issue.
96 XJ:
***** inches...
post #10 of 19 Old 09-03-2013, 09:14 PM
cbenez1
Ah so I had it all confused. Damn it I thought I cleared the 0331 hurdle. So if I see the 0331 without the TUPY my XJ is a potential carrier of the diseased cyl head. Are the 0331 numbers on the intake or distributor side ?
cbenez1 is offline
post #11 of 19 Old 09-03-2013, 09:57 PM
tbburg
If you're asking about the '91 in your profile, it doesn't have the 0331 head. That's a '00-up part.
The "0331" mark is on the driver's side of the head, roughly even with the oil fill port, but it's covered by an aluminum heat shield(at least it is on both my '00 and '04) The "TUPY" mark is viewable from the oil fill port, directly between the rockers, and it is very noticeable. Just look straight down through the hole(requires standing on the bumper.)
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #12 of 19 Old 09-03-2013, 10:15 PM
tbburg
Here, this might help:
Images are thumbnail links to larger photos at photobucket.com
Non tupy head . . . . . . . . . . . . Tupy head
Link to non-tupy head photo
Link to tupy head photo
Both photos are aligned photo-top to back of engine/bottom to front. The "0331" casting mark is under the heat shield at the right of the photo(driver's side of the vehicle)
tbburg is offline
post #13 of 19 Old 09-05-2013, 08:42 AM
cbenez1
No I was checking my 2001. Thanks for the pics
cbenez1 is offline
post #14 of 19 Old 09-06-2013, 08:37 PM
tbburg
Ah,.. the ever-popular problem:
"Fill out your profile!"
"For which Jeep?"
"For the one your asking about!"
"What? You want me to change my profile every time one of those 6 bas****s has a problem?"
tbburg is offline
post #15 of 19 Old 09-07-2013, 08:55 AM
cbenez1
"For which Jeep?"
Yeah exactly. I've got 3. An 01 a 96 and a 91.
cbenez1 is offline
0331 Head WMW0505 XJ Cherokee Technical Forum 138 02-20-2016 08:13 PM
how to tell updated 0331 head from old 0331? Rmart30 XJ Cherokee Technical Forum 3 02-18-2010 12:09 PM
question switching 0331 xj head to 98 tj head. jonnyz123 XJ Cherokee Technical Forum 1 05-15-2009 05:35 PM
0331 head swap 7120 removing the head from 92 to 2000 what all parts are needed amazingman XJ Cherokee Technical Forum 3 05-14-2009 01:57 PM
0331 Cyl Head crack XJride231 XJ Cherokee Technical Forum 1 12-29-2006 12:46 AM
