TruckLite issue - JeepForum.com
post #1 of 7 Old 01-12-2014, 08:32 PM Thread Starter
VTEK1
TruckLite issue
So I had my headlights wired up with a home-brew harness with two relays and about a week ago the high beams started freaking out, and then nothing. I swapped a bunch of relays around, traced wiring...nothing fixed it.
I went back to the stock headlight connectors which I cleaned and got a little bit of corrosion out of. No the high beams come on and flicker, like a very fine flicker; almost like on the motorcycle.
Because the stock connector is what "flips" the relay to high beam I'm thinking thats the issue, so I dived into the fuses and such and nothing.....
Any ideas, it sound kind of like a high beam switch on the column but just want a few opinions and ideas. Thanks.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #2 of 7 Old 01-13-2014, 01:42 PM
uberxj92
1992 XJ Cherokee
You can use a multi meter to watch for the fluctuations from the switch.
I use a home brew harness with 2 relays no issues. Maybe a ground not big enough or dirty.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 7 Old 01-13-2014, 07:46 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
XJ headlight switches are know to stuggle with carrying full amperage load of the lights. The purpose of the re-harnessing is to shift the load to relays fed directly from the battery thus bypassing the switch with the load. I'd pull a quick test wire from the battery positive terminal to the relay trigger to see if they come on properly. If they do, the relays aren't getting a good trigger signal from the switch. If they don't then you have homebrew harness issues. The dim lights and flickering you noted seems to indicate a bad connection.
***Chris***
chris87xj is offline
post #4 of 7 Old 01-13-2014, 09:42 PM
uberxj92
1992 XJ Cherokee
As a side note I use gold plated connectors and I solder them. Its more cost but its worth it
uberxj92 is offline
post #5 of 7 Old 07-17-2014, 03:16 AM Thread Starter
VTEK1
After I took out the homebrew headlight harness and spruced everything up with a combination of dental tools, a wire brush, spray electrical contact cleaner, and dielectric grease.....it seems the high beams will still flicker but only when the Jeep is off. Low beams are fine. It's still a little perplexing considering I'm running a pretty large platinum battery and 4AWG cables for EVERYTHING related to the charging system. But it's all working.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #6 of 7 Old 07-17-2014, 04:15 AM
jay-h
When you say high beams flicker, what is fluctuating? The voltage of coil signal to the relay or the power from the battery under load.
Is it bright/dim or on/off?
There's not much to go wrong here. If the relays are hooked up properly only a very small amount of power is needed from the light switch. You should have a very strong connection to the contacts of the relay from the battery (via fuse).
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #7 of 7 Old 11-29-2014, 10:50 AM Thread Starter
VTEK1
Everything was good with the lights, I noticed when the Jeep is off when I switch on lights they are good, you switch to high beam you get a bright/dim flicker for a few and it's only for a few seconds.....then it just stops and the high beams stay on no problems....I think it was a combination of using the wiring harness and dirty connections. Since they are LED I went back to stock harness and have had no further issues.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
