Troubleshooting XJ 1989 Jeep Cherokee - JeepForum.com
post #1 of 3 Old 02-29-2016, 11:03 AM Thread Starter
CplHudson
1989 XJ Cherokee
Hello guys! Now that I got the jeep started, I figured i'd ask for help on a new thread since its a different issue.
The stats:
1989 Jeep cherokee 4.0L 6 inline cylinder.
Closed system (Renix I believe, no radiator cap on radiator, and a pressure bottle reservoir)
The Problem: Jeep runs, but after about 45-60 seconds it starts to creep up real high on the temp gauge.
I already flushed the coolant out, and replaced the thermostat before I even got the jeep to start.
I fill up the reservoir bottle to the full line, and I don't see any leaks.
When I come back the next day to try again, the bottle is bone dry.
Also, when i pulled off the thermostat housing, there is a waxy like substance all over the inside of it.
Please tell me what I should be checking and what order I should be checking them.
Thanks in advance!
CplHudson is offline
post #2 of 3 Old 03-01-2016, 10:09 PM
Diamond-x
1991 XJ Cherokee
It sounds like you are not putting enough water in it, when the engine cools off it sucks the res dry. Disconnect the radiator hose and fill it slowly until all the air comes out. Make sure that you completely fill the system and the res.
Diamond-x is offline
post #3 of 3 Old 03-01-2016, 10:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Also, get a 703-1396 cap for the reservoir at Napa.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
