Trouble installing rear drivers side window - JeepForum.com
post #1 of 7 Old 02-13-2013, 04:38 PM Thread Starter
theRizzler
I just got my jeep, and the rear driver's side window was busted out. I got a replacement, but I'm having trouble getting the thing in. I read somewhere that I need to take the vent window out, but I can't seem to get it out..
Can someone please give me a hand and tell me the proper way to install the rear driver's side window? I will be eternally grateful.
P.S. I apologize if this has been covered in these forums already, but I searched and could not find any threads with the same issue.
P.P.S. I'm new to the boards, but I think my Jeep's info should show up next to my post.
theRizzler is offline
post #2 of 7 Old 02-13-2013, 04:58 PM Thread Starter
theRizzler
Sorry for the double post, but the main problem I think I'm having (based on instructions I've found around the web on how to replace the windows) is that I can't seem to get out the "glass channel" (the metal guide that goes between the window and the "vent window"). I unscrewed it at the top with a Torx head screwdriver, but I can't find how to actually remove it so that I can take out the vent window..
post #3 of 7 Old 02-13-2013, 05:24 PM
MJR
MJR's Avatar
1988
Behind the outside window belt moulding is a pop rivet holding it.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #4 of 7 Old 02-13-2013, 05:27 PM Thread Starter
theRizzler
I just saw that right before I came back in to check the boards.. Darn, is it safe to bust the rivet out?
post #5 of 7 Old 02-13-2013, 06:24 PM
MJR
MJR's Avatar
1988
1/8" drill bit.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #6 of 7 Old 02-14-2013, 07:15 AM Thread Starter
theRizzler
Yeah I drilled it out last night before I got any responses back on here, but what I meant was: is that rivet really necessary? Do I need to replace it?
post #7 of 7 Old 02-14-2013, 09:01 AM
MJR
MJR's Avatar
1988
If the factory put it in I always put it back but that's up to you. It does support it between the top and bottom.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
install , replace , replacement , window
