Trouble Code Trouble!!! - JeepForum.com
post #1 of 8 Old 04-07-2006, 05:51 PM Thread Starter
Jeepthing88
1994 XJ Cherokee
Exclamation Trouble Code Trouble!!!
i was working on my sisters car today when i decided to take the few seconds to check my 94 cherokee for any trouble codes. well this time i came up with one...it was 13...after looking it up if found that it was "Fault in the map sensor pneumatic circuit".....ok...so now i know what the problem is...or atleast what its called...does anyone know exactly what this is and can explain it in simple terms...i know its something about how the engines running from start and once its started. but that doenst help much and doenst tell me how to fix it. thanks for all your help
Jeepthing88 is offline
post #2 of 8 Old 04-07-2006, 05:55 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
That means that it is time to replace to MAP. Check the vacuum lines to it first though.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 8 Old 04-07-2006, 06:31 PM Thread Starter
Jeepthing88
1994 XJ Cherokee
thats exactly waht i needed to know...thanks.......but could you explain exactly what this thing is...what it does..and of course where do i find it
post #4 of 8 Old 04-07-2006, 08:33 PM
jv3kxj
MAP sensor = Manifold Absolute Pressure sensor. look here http://www.autozone.com/servlet/UiBr...ction=loadPage
jv3kxj is offline
post #5 of 8 Old 04-07-2006, 08:34 PM
jv3kxj
sorry bout the link but here's what is says;
On your 1994 JEEP CHEROKEE 4WD, the M.A.P. SENSOR is:
UNDER HOOD, CENTER, REAR ENGINE AREA, MOUNTED ON UPPER FIREWALL
jv3kxj is offline
post #6 of 8 Old 04-07-2006, 08:43 PM
jv3kxj
e-mail me and I'll send you a pic
jv3kxj is offline
post #7 of 8 Old 04-07-2006, 09:08 PM
Matt Gertsch
www.lp.org
Go buy a Chilton's. If you're a newb at working on vehicals, it'll be the best $12 you can spend.
post #8 of 8 Old 04-08-2006, 04:32 PM Thread Starter
Jeepthing88
1994 XJ Cherokee
thanks alot ill do that
Trouble code help!!!!!! Haleyrz XJ Cherokee Technical Forum 12 09-17-2009 10:53 PM
trouble code 56? jeep1204 XJ Cherokee Technical Forum 6 06-10-2009 10:22 AM
trouble code 27 Ex-Jay XJ Cherokee Technical Forum 5 03-26-2006 05:13 PM
trouble code HEX 3e wcrstereo74 XJ Cherokee Technical Forum 1 10-24-2005 10:34 AM
How to get trouble code from '98 XJ McCarley XJ Cherokee Technical Forum 1 08-16-2005 12:19 AM
