Trouble!!!! - JeepForum.com
post #1 of 4 Old 08-10-2013, 02:22 PM Thread Starter
Tracker1100
Trouble!!!!
I have a 1998 Jeep Cherokee Limited with a 4.0 6 cyl. engine and an AW4 transmission. Just had the computer read and it is throwing 8 codes. Drove the jeep threw some deep water recently and all these issues are now showing up all at once. A/C doesn't blow cold anymore, the transmission has 1st gear only and the engine idles rough (surging, high idle). Any idea if one thing maybe causing all these issues/codes?
P0545
P0443
P1698
P1899
P0700
P0122
P0705
P1491
Tracker1100 is offline
post #2 of 4 Old 08-10-2013, 10:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Always fix the lowest number trouble codes first. Higher number trouble codes are often caused by the faulty data the lower number code causes.
You mention water, TPS related symptoms, and the lowest numbered code is for the TPS. The TPS hates getting wet and can be ruined by excessive moisture. The TPS also has input to the transmission computer.
P0122 Jeep - Throttle Position Sensor/Accelerator Position Pedal Circuit Low Input
Possible causes
- Faulty throttle position sensor
- Throttle position sensor harness is open or shorted
- Throttle position sensor circuit poor electrical connection
Replacing the TPS with a genuine Jeep part should cure the problem and solve most or all of the higher numbered trouble codes. Cheap crappy "Lifetime Warranty" parts are often out of specification or even failed right out of the box. Many times they have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep sensors.
CJ7-Tim is offline
post #3 of 4 Old 08-11-2013, 10:09 AM Thread Starter
Tracker1100
Thank You Tim!!!
post #4 of 4 Old 08-14-2013, 06:10 PM Thread Starter
Tracker1100
CJ7-Tim, you were dead on with the TPS!!! Changed it out and it runs good. Thanks again!!!
