tricks for lower ball joint removal please... - JeepForum.com
post #1 of 22 Old 03-07-2007, 05:00 PM Thread Starter
96yeepster
as topic says this thing is a biatch....
96yeepster is offline
post #2 of 22 Old 03-07-2007, 05:53 PM
andrew2516
balljoint press
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
andrew2516 is offline
post #3 of 22 Old 03-07-2007, 06:03 PM
AZ Jeff
2014 JK Wrangler
Originally Posted by andrew2516
balljoint press
agreed. Are you using one, and do you have the correct adapters?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 22 Old 03-07-2007, 07:41 PM
Klutch
It's all about the tools, my friend. Without a ball joint press, you might as well be using your bare hands and nothing else.
Advance Auto and Checker Auto will "loan" you the ball joint press. The way it works is you buy it and when you bring it back, they refund your money. This isn't taking advantage of the return policy, or anything. It's supposed to work this way and it's yet another reason America is a great country.
Klutch is offline
post #5 of 22 Old 03-07-2007, 07:49 PM Thread Starter
96yeepster
yeah I got a press.
I however cannot get it to sit square on the lower joint.
The upper was no problem.
I was wondering more if I should have left the top out then removed/installed bottom or the like.
post #6 of 22 Old 03-07-2007, 09:37 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
I think you hit the nail on the head.
It may just be the ball-joint kit I bought but I can't work on the lowers without removing the uppers.
You may be able to by a cup/sleeve combo that will remedy your problem but I'm not aware of one.
My ball-joint routine has always been to remove upper, remove lower, replace lower, replace upper. If you have access to a wider selection of sleeves and cups than I do maybe you can be more flexible. With my limited access to tools I'd pull the upper and start over. Hopefully someone has more productive advise.
Happy wrenching
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #7 of 22 Old 03-07-2007, 11:07 PM
MGrobe
Man In Black
MGrobe's Avatar
When I did mine I bought a press from OTC with the appropriate Jeep adapters. Look on page 2 of this PDF for a usage diagram to make sure your pressing correctly.
http://www.grobe.us/Jeep/Tech/Drivet...JointPress.pdf
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #8 of 22 Old 03-08-2007, 07:25 AM Thread Starter
96yeepster
Happy wrenching
thats what I get for trying to save time not waiting for wife.
And haynes for writing such a $hitty book... I swear half their replies to repairs is take to dealer...
post #9 of 22 Old 03-08-2007, 08:33 AM
XJH-007
XJH-007's Avatar
I had to cut a section of pipe to fit the BJ. None of the pieces that came with the kit would fit well enough.
Also, tighen the press down good and tight, then give the knuckle a few good raps with a hammer, tighten it down again and repeat with hammer. Keep doing that till it POPS.
That will knock her loose without you haveing to put a 10 foot lever on the press, possibly damaging it....
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #10 of 22 Old 03-08-2007, 02:04 PM Thread Starter
96yeepster
the press is a autozone rental so I am not concerned with damaging it.
But yeah leaving those uppers out did the trick. Got the drivers side finished (minus tie rod end) in about 30 minutes.
Did the pass side start to finish in about 1:45.
That time I also left that damned tie rod end hooked up.
Do it once and learn from it...
post #11 of 22 Old 03-08-2007, 06:55 PM
89xjsteveo
1989 XJ Cherokee
hey i just replaced my balljoints yeasterday.
for the bottom one i heated the metal araound it till it was cherry red then i took a big *****$ hammer it after a few good hitts it popped right out.
89xjsteveo is offline
post #12 of 22 Old 08-26-2013, 09:44 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Not to drag up an old thread, but I need some help. I snapped all of the lug studs and lost a wheel this morning. At first I thought it was just 5 studs and a rotor to fix it. But I noticed the bottom of the lower ball joint is ground down. I'm trying to figure out how to get it out. Also, what has to come out in order to remove it?
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #13 of 22 Old 08-26-2013, 02:12 PM
MGrobe
Man In Black
MGrobe's Avatar
Yikes! That is definitely ground off! You still will have to separate the inner and outer knuckles. The outer knuckle is still pressed onto the ball joint stems. So remove any castellated nuts that may still exist (probably just the upper) and take a hammer to pop the knuckle down off the ball joint stems. Then using a ball joint press and remove the upper and lower ball joints.
-Marc-
Sweet Pea 1998 - XJ
MGrobe is offline
post #14 of 22 Old 08-26-2013, 02:18 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
That's what I'm planning on doing. I'm still fighting with the unit bearing to try to take the steering knuckle off.
dagr8tim is offline
post #15 of 22 Old 08-26-2013, 02:22 PM
MGrobe
Man In Black
MGrobe's Avatar
What part are you having issues with? The large axle nut?
-Marc-
Sweet Pea 1998 - XJ
MGrobe is offline
lower ball joint problem jeepnphreak XJ Cherokee Technical Forum 2 08-07-2009 07:58 AM
Stubborn lower ball joint castle nut Jeeprs89 XJ Cherokee Technical Forum 4 07-14-2009 09:54 PM
Can't get out lower Ball joint CharlieMopps XJ Cherokee Technical Forum 23 10-22-2008 04:20 PM
Lower Ball joint. nujeepguy XJ Cherokee Technical Forum 7 02-17-2008 06:43 PM
Greasable lower ball joint? NotMatt XJ Cherokee Technical Forum 3 02-17-2004 10:04 PM
