Trick to remove stuck rotor - JeepForum.com
post #1 of 19 Old 10-17-2010, 11:42 PM Thread Starter
JTrue
Just read this on another forum while changing out my axle shaft u-joints. No matter how hard I hit the rotor with a 5 lb sledge it wouldn't come free. Trick is to go to the hardware store and buy ( 2)m8 1.25 thread(iirc) 60mm in length and nuts to go on the end. Remove the caliper and thread the bolts into the caliper bracket holes from the back. Thread the nut on after the bolt is through the bracket hole. Use the bolts to push against the back of the rotor slightly, then hit with a sledge. Repeat tightening and hitting until the rotor pops off. Took less then 5 minutes using this method. Only a couple nicks in the rotor, that won't cause any issues. Seems like common sense now, but I hadn't seen this before. Hope it helps someone.
JTrue is offline
post #2 of 19 Old 10-18-2010, 06:47 AM
lowicz96
1995 XJ Cherokee
Did you try heat? Heat is your friend
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #3 of 19 Old 10-18-2010, 08:25 AM Thread Starter
JTrue
Didn't try heat, you think a propane torch would work? Or do you need oxy-acetylene to do anything? I know from past experience when I was trying to get a stuck tie-rod end off a propane torch didn't do anything. Took it to the shop I worked at and the oxy-acetylene allowed me to pop it right off.
Don't really have the cash to buy a torch, so this is the poor man's way, under $4.
JTrue is offline
post #4 of 19 Old 10-18-2010, 09:51 AM
Whistler31
1995 XJ Cherokee
propane wont get hot enough with out extended heating. a much easier and cheaper soloution is to get a mapp gas torch. they look just like the propane ones except for the big yellow bottle. the tank lasts a good long time but the are a good step up from propane. they are alot hotter than propane. not as hot as acetylene, but usually get the job done. I got mine for $60. the new tanks arent that expensive.
Whistler31 is offline
post #5 of 19 Old 10-18-2010, 10:33 AM
lowicz96
1995 XJ Cherokee
any heat is good heat
lowicz96 is offline
post #6 of 19 Old 10-18-2010, 11:00 AM
keepishop
1989 XJ Cherokee
Or just wedge something between the rotor and the axle knuckle and turn the steering wheel a tad.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #7 of 19 Old 10-18-2010, 11:44 AM Thread Starter
JTrue
Yeah, that's how I popped the hub assembly off.
JTrue is offline
post #8 of 19 Old 10-18-2010, 12:50 PM
maddmaxjack67
When I did mine, the rotors were really really stuck, I got a three prong puller and took an electric impact to it.
*2000 Red XJ: DEAD
*1997 Gun Metal Blue XJ: DEAD
*1984 Mustard Yellow FSJ Wagoneer: SOLD
maddmaxjack67 is offline
post #9 of 19 Old 10-18-2010, 06:37 PM
btoohey44
Slightly off topic but not really...when I was younger I was changing the rear-drums on my 95 Escort. Just got done changing the front pads and rotors and was moving on the the rears. Driver's side rear came right off, no issues, the passenger side rear would NOT come off. No matter what I did I could not get the drum off. After throwing the pry-bar and beating the heavy bag up I remembered to release the e-brake...
btoohey44 is offline
post #10 of 19 Old 10-18-2010, 07:02 PM
lifesabeach01
Just drill some little pilot holes around the edge of the rotor and the axle and spray some pb blaster or something back there and let it sit and then try hitting it with a bigger sledge.
lifesabeach01 is offline
post #11 of 19 Old 10-18-2010, 07:08 PM
XJcruiser
I did this once and got 2 pieces. Came off though!
XJcruiser is offline
post #12 of 19 Old 10-18-2010, 10:45 PM
nrpalmer32
1987 XJ Cherokee
Just thought I'd throw in some fuel to heat temp specs from my school's welding book.
Acetylene = 5589*F flame
MAPP = 5301*F flame
Natural Gas = 4600*F flame
Propane = 4579*F flame
Propylene = 5193*F flame
Hydrogen = 4820*F flame
nrpalmer32 is offline
post #13 of 19 Old 10-19-2010, 06:43 AM
lowicz96
1995 XJ Cherokee
wow didnt know MAPP was that close to acetylene.
lowicz96 is offline
post #14 of 19 Old 10-19-2010, 07:55 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
yea pullers are NOT recommended if you want to keep the rotor...rotors are not meant to be flexed like that. Plus they put stress on the hub bearings and could cause them to fail.
My tool of choice?
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #15 of 19 Old 10-19-2010, 08:10 AM
justanotherjpr
BFH is usually my tool of choice.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
What's the best way to remove stuck oil pan? limited XJ Cherokee Technical Forum 5 09-11-2009 11:55 AM
whats the trick? BUSHINGS STUCK 01GreenXJ XJ Cherokee Technical Forum 6 04-03-2009 04:31 PM
whats the trick? BUSHINGS STUCK 01GreenXJ XJ Cherokee Technical Forum 1 04-02-2009 07:52 PM
Stuck Rotor Paybac XJ Cherokee Technical Forum 3 04-05-2008 11:39 PM
remove lower dash? stuck. tozier9 XJ Cherokee Technical Forum 2 01-31-2007 08:24 AM
