Transmission Trouble? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Transmission Trouble?
Jeep Grand Cherokee Mirror - Side ViewJeep Grand Cherokee Header PanelTJ 5.25" Speaker Adapters - NalinMFG
Unread 06-01-2014, 06:47 AM   #1
ianthart89
My Stock 1998 Jeep Cherokee Limited V6 4.0L 2wd is whining and High revving in 1st and 2nd gears. Any ideas as to possible cause. Everything is stock.
ianthart89 is offline   Reply With Quote
Unread 06-01-2014, 07:51 AM   #2
xjoverkill
Manual transmission or auto?
98 XJ 5 speed
xjoverkill is offline   Reply With Quote
Unread 06-01-2014, 07:52 AM   #3
xjoverkill
I am guessing auto. And no that is not normal. Sounds to me like shift flare.
98 XJ 5 speed
Unread 06-01-2014, 01:40 PM   #4
Ratrod
Check the fluid in the trans and what color is it?
1996 RHD XJ
Ratrod is offline   Reply With Quote
Unread 06-02-2014, 08:58 AM   #5
ianthart89
Auto Tranny, RWD.
I just it serviced at Tire Kingdom 2 days prior to the noise starting checking and topping off the fluids was part of the service package. I had been in a spin out due to collision avoidance on Memorial Day.
Unread 06-02-2014, 11:17 AM   #6
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Originally Posted by ianthart89 View Post
Auto Tranny, RWD.
What type of fluid was installed ? The AW-4 automatic trans uses Dexron-III/Mercon. Incorrect trans fluids can cause shifting issues or a whine.
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 06-03-2014, 10:48 AM   #7
ianthart89
I will have to look at the invoice, I just had them top it off. I did not know about the specific transmission fluid until your post. Thanks.
If they did use wrong stuff it is blessing and a curse. I will get a free transmission flush and new fluid but the downside is I will have to sit in the lobby again.
