Transmission Swap - JeepForum.com
post #1 of 1 Old 05-09-2008, 05:33 PM Thread Starter
gregpalin
1987 YJ Wrangler
Transmission Swap
I drive a YJ, with a 1989 4.0L cherokee engine (renix). There is a bad vibration at about 1500rpm under load that I beleive is the transmission failing (blown bearing) It is a automatic tranny and I would like to swap it with a manual. Does anyone know which models I can go with, considering length of driveline (is a manual transmission phsyically longer than the auto? (AW4)), (is the tranny mount compliant?). As well as considering transfer case placement (driverside) The swap should go well as the YJ was originally a manual
gregpalin is offline
transmission swap corwin117 XJ Cherokee Technical Forum 3 05-16-2009 07:27 AM
Transmission swap johngus MJ Comanche Technical Forum 1 03-12-2007 12:29 AM
Transmission swap jasfro XJ Cherokee Technical Forum 1 11-18-2005 06:17 PM
[b]transmission Swap[/b] BenPi XJ Cherokee Technical Forum 6 06-24-2005 05:58 PM
transmission swap 88XJ_WI XJ Cherokee Technical Forum 5 09-16-2004 07:45 PM
