Transmission stuck in 1st gear - JeepForum.com
post #1 of 30 Old 09-15-2006, 07:46 PM Thread Starter
watkins 92 yj
watkins 92 yj's Avatar
well, now that i think i've figured out my overheating issues, i went for a test drive and my transmission wouldn't shift out of first gear. i shifted through the transfer case gears and had the same result. all i know what to do with an automatic transmission is check the fluid. i did this and the fluid level was on the full mark and the fluid looked as clear / red as it could be. any help would be appreciated.
watkins 92 yj is offline
post #2 of 30 Old 09-15-2006, 07:49 PM
TMXONR
TMXONR's Avatar
1987 XJ Cherokee
Does your speedometer work? Idk if it is the same on a jeep, but on my eclipse the speed sensor went out. Once it went out the speedometer didnt work, and the trans stayed in first gear.
TMXONR is offline
post #3 of 30 Old 09-15-2006, 08:02 PM Thread Starter
watkins 92 yj
i works, but bounces around a little. this is my brother's jeep and its the first time i've driven it. he is at work and i'm working on the jeep. i don't have any way to get ahold of him til he gets off work to ask how well the speedometer works.
post #4 of 30 Old 09-15-2006, 08:08 PM
karacer
karacer's Avatar
1993 XJ Cherokee
Throttle Position Sensor.
Don't remember how to check it,maybe someone can chime in with that. There is a way to check it with a meter. Don't remember if mine threw a CEL or not.
karacer is offline
post #5 of 30 Old 09-16-2006, 11:26 AM Thread Starter
watkins 92 yj
i forgot to mention that this happened all of a sudden. it had been shifting fine.
post #6 of 30 Old 09-16-2006, 01:16 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Transmission control unit go out?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 30 Old 09-16-2006, 04:51 PM Thread Starter
watkins 92 yj
i really have no idea what happened. i appreciate the suggestions though. thanks
post #8 of 30 Old 09-16-2006, 05:29 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Use our suggestions and start lookin
Troubleshooting sucks. Repairing is the fun part!
-Matt
White '94 YJ Sport
UltimatE is offline
post #9 of 30 Old 09-16-2006, 06:35 PM Thread Starter
watkins 92 yj
well, i'm off the next 3 days and my bro is off mon and tues. i'll try your suggestions and let you know how it goes. one problem.... on monday, i'll receive my RE greasable shackle kit and will have to put my brother's jeep on standby for the day
post #10 of 30 Old 09-16-2006, 07:08 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
To rule out any mech rans issues, disconnect the TCU and shift manually through the gears.
Check the TPS voltage and make sure it's good.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #11 of 30 Old 09-16-2006, 07:28 PM
XJ ARTY
Mine did exactly the same thing I have a 96 Classic and about a month ago I changed all of the outside bushes on the transfer case linkage and when I went to drive it the transmission stayed in 1st gear would'nt change, and it had been changing just fine up until then. i took it to a Transmission shop and after checking the TPS found that to be OK, He removed the pan and dropped the valve bodies and found the kick down valve stuck,its located up inside the case, touched it with his finger and it freed itself, gave the trannie a good flush put new fluid in and its been changing just fine. cost me $350 he gave the transmission a clean bill of health and told me thats the first one he had come across that had done that. Hope this helps you out.
XJ ARTY is offline
post #12 of 30 Old 09-16-2006, 11:29 PM Thread Starter
watkins 92 yj
i'll pull the pan tomorrow and see if i can see what you just explained. that makes some serious sense.
post #13 of 30 Old 09-17-2006, 12:50 AM
tarvis
1989 XJ Cherokee
its happened to me and my friend at the same time, i dont know if it was the weather, but it was the tps, his is the an 88 motor and mines the high output
1997 XJ 4x4 4.0H.O./AW4
-R.E. Super Ride 3.5'' w/ daystar 1 3/4'' shackle and coil spacer. R.E. AAL 3.5/Rustys AAL 3.5
-32'' Remington Mud Dawgs on 15x8 U.S. Wheel Daytonas (black)
-No muffler, dumped before axle, K&N air filter
-homemade rack/bumper with six 55w 5 inch lights attached
tarvis is offline
post #14 of 30 Old 09-17-2006, 01:18 AM
Rock Kustoms
Rock Kustoms's Avatar
WOOOOOAH..... hold on. this is in the XJ section, so it has an AW4 as long as it was made between 89 and 01. therefore, it doesnt have a kick down cable!
its going to be something electrical id bet, do as balloo suggested.
Rock Kustoms is offline
post #15 of 30 Old 09-17-2006, 08:16 AM
XJ ARTY
Well mine is a XJ 96 Classic and it has the kick down cable but I live in Australia maybe they did them different for Down Under I had the same problem with mine stuck in first and that was the cause.!!!!!!
XJ ARTY is offline
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 12:51 PM
transmission stuck in 3rd [i think] camxxxl XJ Cherokee Technical Forum 1 01-15-2010 09:53 AM
Transmission Oil Pan Stuck louisd11 XJ Cherokee Technical Forum 19 05-13-2009 10:07 AM
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 02:30 AM
Transmission stuck in gear Jeepthing88 XJ Cherokee Technical Forum 4 12-25-2007 09:58 AM
