Quantcast Transmission shifts to OD at 35 mph? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Transmission shifts to OD at 35 mph?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-19-2009, 10:18 PM   #1
scottyknows50
1987 XJ Cherokee
The transmission on my '87 Cherokee has been shifting strangely- when I am trying to merge on the interstate it quick shifts up to overdrive by the time I reach 35 mph. Flooring it doesn't do anything. If I leave the shifter in 3rd it will rev and shift normally and I can put it into OD when I'm on the interstate. What would cause it to shift up so quickly and not want to downshift? Anyone else experience this? Thanks. It's the AW4 tranny- I believe.
scottyknows50 is offline   Reply With Quote
Old 11-19-2009, 10:47 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
TPS is more than likley going out. You can check it with a volt meter.
Jeep Cherokee TPS Adjustments
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 11-19-2009, 10:50 PM   #3
pentastar01
Try adjusting the kickdown cable. Sorry, but I don't know how to, somebody should.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline   Reply With Quote
Old 11-19-2009, 11:08 PM   #4
1990JEEPXJ
1990 XJ Cherokee
flip the tranny switch to power mode while youre at it. but i think it also has to do with the TPS.
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 11-19-2009, 11:11 PM   #5
scottyknows50
1987 XJ Cherokee
that tps seems to be a troublesome bit........
Old 11-19-2009, 11:13 PM   #6
1990JEEPXJ
1990 XJ Cherokee
yes on renix XJ's especially. they are adjustable as well so you cant just throw it in. youll need a voltmeter to put it in and have it operate correctly. its fairly easy though
Twin 242's
The 'build' thread
Old 11-19-2009, 11:30 PM   #7
scottyknows50
1987 XJ Cherokee
i guess i need a voltmeter
Old 11-19-2009, 11:36 PM   #8
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If you own a Renix (87-90) you need a volt meter. You can troubleshoot damn near any propblem with a volt meter on the Renix. IMO it's a must have.
93 Sport
Specs in Profile.
Old 11-20-2009, 12:50 AM   #9
carnuck
1984 J-Series Truck
TVS cable out of adjustment or kinked (tighter it is, the lower speed the upshift)
carnuck is offline   Reply With Quote
Old 11-20-2009, 05:57 AM   #10
cruiser54
1990 MJ Comanche
Check the "trans" fuse in the fusebox to see if it's blown. I found that my power/comfort switch was shorted internally and blew that fuse. The Jeep defaults to the comfort mode without power to the switch circuit. It's easy to remove the faulty switch and do a permanent bypass on the switch plug.
cruiser54 is offline   Reply With Quote
Old 11-20-2009, 09:29 AM   #11
scottyknows50
1987 XJ Cherokee
good thing to check- i have never been able to tell the difference when i switched between the two. maybe my fuse is blown. i removed and cleaned my tps and i'm thinking i put it back on incorrectly- will just need some adjustment i hope.
Old 11-20-2009, 10:00 PM   #12
cruiser54
1990 MJ Comanche
If you don't notice any difference between power and comfort modes, I bet the trans fuse is blown. Shifts up quickly and drives real doggey in comfort/default mode. I would suspect fuse before TPS but it ain't a bad idea to set your TPS anyway. If the switch is bad/fuse blown, pull the switch, remove the connector and jump the two wires in the harness connector that aren't solid black. Then replace the fuse and you wil have permanent power mode.
Old 11-20-2009, 10:02 PM   #13
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If the trans computer is toast or the fuse is blown it will stay in 1/2 and will not shift unless you manually work the shifter.
So if it's bad and you start it up and put it in OD the thing will bogg or stall. If you start it up and shift to 1/2 then 3rd then OD and it runs great then you know the TCU is not working.
93 Sport
Specs in Profile.
Old 11-21-2009, 06:00 AM   #14
cruiser54
1990 MJ Comanche
balloo93 made me think of something. Have you looked for the "other" trans fuse also? It's taped to the harness up under the dash by the passenger side knee bar. Easy to find. Make sure it's not blown and the connections are clean at the holder.
Old 12-02-2009, 11:46 PM   #15
scottyknows50
1987 XJ Cherokee
my TPS output voltage won't go below 4.1 and the input voltage is at 4.6- a ratio of about .89. i know it's supposed to be .83- does this mean that i need a new TPS? how much do they run?
1987 Jeep Cherokee 4x4
339,000 miles and counting....
Glock Forum
