Transmission Rattle - JeepForum.com
post #1 of 5 Old 06-01-2007, 06:42 AM Thread Starter
RPratt08
Transmission Rattle
When I idle or go up hills I can hear a transmission rattle. (Automatic Transmission) Is this a problem or a common thing for my 2000 Jeep Cherokee Sport?
RPratt08 is offline
post #2 of 5 Old 06-01-2007, 07:56 AM
bee guz
Its more than likely the crossbar for the transfercase shifter, I loosened the bolts on the cross shaft, just a few turns, so it floats, I tried makeing shims out of hose but this seems to work the best.
there are 2 small bolts about 10mm, where the shaft runs in to the bracket on the tunnel, just loosen them a few turns so the shaft ahs some give, don't remove them, the rust on the bolts will hold them so they wont back out, anymore.
I did the ones on my XJ a few months ago the rattel was driveing me nuts...
bee guz is offline
post #3 of 5 Old 06-01-2007, 08:05 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
In addition to the previous, also check your exhaust, and make sure it is not rattling against your crossmember. Mine is, and is making the same sound as youre describing.
88XJSport is offline
post #4 of 5 Old 06-01-2007, 09:36 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
That, and give your CAT a rap with a soft hammer to make sure the catalyst hasn't broken up and is rattling.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #5 of 5 Old 06-01-2007, 11:16 AM
liquidforceb069
liquidforceb069's Avatar
mine does it going up hills.. maybe thats what thats been the whole time... i have all new exhaust so hmmmm.. tranny ouch
98 XJ Sport
8.5" BDS LA With Gas Shocks
Allied Rock 8 32Blt Beadlocks With 35" Trxus M/T's
RE Hack N' Tap
RE CVF Driveshaft 33.5" In Length
Warn Front Bumper With Winch
IPF Headlight Conversion
Drawtite Roof Rack
15% Tint All Around
Autolite Iridium XP Plugs And Wires
Optima Red Top
Tow Rig
2000 Dodge Ram 2500 Black
liquidforceb069 is offline
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 01:30 AM
Rattle Rattle Rattle Rattletrap TreddyoXJ XJ Cherokee Technical Forum 5 04-16-2007 08:22 PM
strange engine/transmission noise and oil leaking from transmission? weldmaster4000 XJ Cherokee Technical Forum 5 04-20-2006 01:06 PM
Rear sound bar rattle? (Rattle bar?) Fix suggestions! Alexia XJ Cherokee Technical Forum 9 11-16-2004 09:07 AM
Rattle in 4.0L also XJ Cherokee Technical Forum 5 04-02-2003 12:06 AM
