transmission question - JeepForum.com
post #1 of 6 Old 02-02-2013, 05:47 PM Thread Starter
JeepCherokee513
1994 XJ Cherokee
I have a 96 cherokee 4.0 4x4, np231 transfer case, AW4 transmission..
When i drive it for about 20 minutes the trans will act like its in neutral then jump back into gear.. without moving the pedel it will rev up then kick back into gear. figured maybe my trans was going out, today it had no power like it was taking off in like 3rd gear so i turn it off then back on and full power.. It only does this every now and then, i have changed the fluid in transfer case and transmission, any suggestions? comments?
JeepCherokee513 is offline
post #2 of 6 Old 02-02-2013, 05:49 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
There are a few possibilities, but I always start with simple to more complex. The "throttle position sensor" is almost always in play for symptoms with the AW4 transmission, as it provides a very important input signal to the computer.
You can test the TPS, but testing may not be of value unless the symptom is present. I have seen the TPS be subject to heat related failure. If testing is inconclusive, I'd certainly replace it before condemning the transmission.
The throttle position sensor is connected to the throttle shaft on the throttle body. It sends throttle valve angle information to the PCM. The PCM uses this information to determine how much fuel the engine needs. The TPS is really just a simple potentiometer with one end connected to 5 volts from the PCM and the other to ground. A third wire is connected to the PCM. As you move the accelerator pedal with your foot, the output of the TPS changes. At a closed throttle position, the output of the TPS is low, about a half a volt. As the throttle valve opens, the output increases so that, at wide open throttle, the output voltage should be above 3.9 volts. Testing can be performed with an electrical meter. Analog meter is best. You are looking for a smooth sweep of voltage throughout the entire throttle band. While slowly opening and closing the throttle, take note to the movement of the voltmeter needle. There should be a direct relationship between the needle motion to the motion of the throttle. If at anytime the needle moves abruptly or inconsistently with the movement of the throttle, the TPS is bad
You should have 5 volts going into the TPS. At idle, TPS output voltage must be greater than 200 millivolts. At wide open throttle (WOT), TPS output voltage must be less than 4.8 volts.. The best is to use an analog meter (not digital) to see if the transition from idle to WOT is smooth with no dead spots. With your meter set for volts, put the black probe on a good ground like your negative battery terminal. With the key on, engine not running, test with the red probe of your meter (install a paper clip into the back of the plug of the TPS) to see which wire has the 5 volts. One of the other wires should show .26V (or so). The other wire will be the ground and should show no voltage. Move the throttle and look for smooth meter response up to the 4.49 at WOT.
Perform the test procedure again and wiggle and/or tap on the TPS while you watch the meter. If you notice any flat spots or abrupt changes in the meter readings, replace the TPS.
The TPS is sensitive to heat, moisture and vibration leading to the failure of some units. The sensor is a sealed unit and cannot be repaired only replaced. A TPS may fail gradually leading to a number of symptoms which can include one or more of the following: -
NOTE: The throttle position sensor is also DIRECTLY involved with transmission shifting characteristics! It should be verified early in the troubleshooting process, when a transmission issue is suspected!
• Poor idle control: The TPS is used by the ECU to determine if the throttle is closed and the car should be using the Idle Air Control Valve exclusively for idle control. A fault TPS sensor can confuse the ECU causing the idle to be erratic or "hunting".
• High Idle Speed: The TPS may report faulty values causing the engine idle speed to be increased above normal. This is normally found in conjunction with a slow engine return to idle speed symptom.
• Slow engine return to idle: A failing TPS can report the minimum throttle position values incorrectly which can stop the engine entering idle mode when the throttle is closed. Normally when the throttle is closed the engine fuel injectors will be deactivated until a defined engine RPM speed is reached and the engine brought smoothly to idle speed. When failing a TPS will not report the throttle closed and fueling will continue causing the engine to return to idle very slowly.
• Engine Hesitation on Throttle Application: The TPS is also used by the ECU to determine if the driver has applied the throttle quicker than the Manifold Air Pressure sensor can read. The fueling is adjusted accordingly to cope with the sudden increase in air volume, however a faulty sensor can cause the ECU to ignore this data and the engine will "hesitate" when applying the throttle. In extreme cases with the engine at idle, a sudden application of full throttle can stall the engine.
• Engine Misfire: A fault TPS can report values outside the denied acceptable range causing the ECU to incorrectly fuel the engine. This is noticeable as a slight misfire and can trigger the misfire detection software and/or Malfunction Indicator Lamp (MIL) light on the dashboard. Extreme cases can cause excessing misfires resulting in one or more cylinders being shut down to prevent engine and catalytic converter damage.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #3 of 6 Old 02-02-2013, 05:53 PM Thread Starter
JeepCherokee513
1994 XJ Cherokee
would the tps show a check engine light? it is not on by the way.
post #4 of 6 Old 02-02-2013, 06:02 PM
tjwalker
tjwalker's Avatar
Sometimes yes, sometimes no. The OBD system absolutely does not cover everything.
Not by a long shot.
post #5 of 6 Old 02-02-2013, 06:08 PM Thread Starter
JeepCherokee513
1994 XJ Cherokee
ok, well i guess i'll buy a tps in the morning and throw it on, any specific way to install it? and tips?
post #6 of 6 Old 02-03-2013, 12:33 AM
Reptile
1991 XJ Cherokee
TPS is a strong possibility, and won't always throw a code. A tip? Get one from the dealer.
You should run the tests above before you spend money on a new one, especially when you're shooting in the dark. Among the other things you should also check: transmission fluid level & connections at TCM (under passenger dash). You could also have a bad transmission solenoid.
Reptile is offline
aw4 , cherokee , slipping , trans , transmission
