transmission power or comfort switch 89 xj - JeepForum.com
post #1 of 16 Old 03-02-2015, 01:31 PM Thread Starter
1989Cherokee4L
Hi, yes been told that I must have the power mode switched on for the transmission, but what function does this provide please and how does it affect the transmission, power or comfort, what happens when I switch either on?
1989Cherokee4L is offline
post #2 of 16 Old 03-02-2015, 04:13 PM
austin6137
1990 XJ Cherokee
Changes the shift points of the trans. Nothing special
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #3 of 16 Old 03-02-2015, 05:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. And it performs better in Power mode. Factory made that mode standard in mid 91 or so.
Does your switch light up when Power is selected?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 16 Old 03-02-2015, 07:51 PM
skyway0018746
In comfort mode it softens the shifts by using less pressure to shift . This will cause premature transmission failure .
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #5 of 16 Old 03-02-2015, 09:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pressure is controlled by the TV cable. No problems with premature trans failure on one of the best, if not THE best automatic transmissions ever developed.
post #6 of 16 Old 03-03-2015, 11:53 AM Thread Starter
1989Cherokee4L
Thanks, yes the power light comes on on the switch, when switched on, not sure I notice any difference up and down gears or kick down. Pretty fed up with modern cars pulling out of side roads in front of me on 50 mph roads I use, just seems easier to overtake than brake where possible.
post #7 of 16 Old 03-03-2015, 01:36 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The switch could be bad inside. Here's what I do:
Bypassing the Power/Comfort Switch on a Renix Jeep
Remove and unplug the switch. In the harness are 3 wires One has a stripe, one is tan, and the other black. Make a 4" jumper wire with a male spade at each end. Plug one end in the cavity for the tan wire and the other in the cavity for the striped wire and you'll be in permanent Power mode. Stuff the harness back in and reinstall the switch for looks.
If you happen to have a 91 or 92 XJ/MJ and it has the Power/Comfort switch, just jumper the Tan and Blue wires in the harness plug.
NEVER include the black wire when jumpering!!!
post #8 of 16 Old 03-09-2015, 10:07 AM Thread Starter
1989Cherokee4L
Thanks I will have ago at making, the jummper wire looks heavy duty voltage where could I obtain wire same spec?
post #9 of 16 Old 03-09-2015, 03:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Needs not be any larger than the wires at the plug.
post #10 of 16 Old 03-22-2015, 06:07 PM
mtnsammy
1990 XJ Cherokee
Not to hack this thread but I am having problems with shifting. It acts like no vacuum mod. on the old C6 transmissions. Unless I manually shift it goes up so quick I have no power. I found the vacuum line disconnected and still working that part but could this failed switch also cause some of it? Still figuring out how this thing shifts.
mtnsammy is offline
post #11 of 16 Old 03-22-2015, 07:36 PM
skyway0018746
It doesn't need vacuum to shift. Start a new thread to get more help. Or search .
post #12 of 16 Old 03-22-2015, 09:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Which vacuum line? This tranny relies on NO vacuum input for shifting. Only the TPS and Power/Comfort switch. The harshness or firmness of shifts is regulated by the tV cable.
post #13 of 16 Old 03-24-2015, 10:04 AM
1stockjeep
1993 XJ Cherokee
Speedometer work? I had a c6 so I know what u mean. It's just shifting thru the gears quickly with no kind of variation with the throttle
1stockjeep is offline
post #14 of 16 Old 12-30-2016, 09:29 PM
mattrowe
1990 XJ Cherokee
Does the gas mileage go down in power mode.
mattrowe is offline
post #15 of 16 Old 12-31-2016, 07:11 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not a bit. Might even go up.
http://cruiser54.com/?p=435
