Transmission mount/ Crossmember question - JeepForum.com
post #1 of 15 Old 11-11-2013, 09:39 PM Thread Starter
XJ_300
Before anything, I want to say hello to everyone as a new member. I have recently bought my very first Jeep and I am very excited about all the experiences a head. I have been a car guy for as long as I remember but most of my car knowledge is from working on Japanese cars. I have recently traded one of my car for a beautiful 2 Door XJ and after a couple weeks of owning the Jeep, it was stolen from my business. However, the cops recovered the car before a lot of damage was done and now as a new project, I am trying to put the jeep back together.
First 5 pictures are the jeep before it went missing.
The engine and transmission was out when the cops found it. The harness was unplugged and the front end was off. I did some work to the motor and changed a few things. I figured to start with putting the engine and transmission together and dropping it in to the car. So half way through the process and after looking around for all the parts that they found with the car, I noticed that the transmission cross member is missing. The car has a lift so my first though is that the cross member was upgraded from the stock one. (btw I apologize if I don't call the parts by their correct name or spell something wrong. also as I mentioned, I am very new but very interested to learn so if I think of something incorrect, please give me the correct information.) Since the Jeep is lifted, there are two mounts (look like aftermarket mounts) bolted to the body of the car where normally the cross member usually bolts on.
Can someone please tell me what options do I have? also what's the best and most efficient way of getting it fixed.
Thanks
Last edited by XJ_300; 11-11-2013 at 09:41 PM. Reason: didn't see the pictures i have tried to upload
XJ_300 is offline
post #2 of 15 Old 11-11-2013, 09:48 PM
Azzy
Of your crossmember is gone, you can pull one form just about any XJ with the same trans. 00 and 01 will require a different trans mount, which cost more. They swap back and forth.. my wife has a 95 crossmember on hers (I had 2 mounts for mine and she needed one.. add in spare parts... )
If you werent clear on the other coast I would say I could ship you mine for the cost of shipping and a tasty beverage. More cost effective for you to raid the junkyard.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #3 of 15 Old 11-11-2013, 10:06 PM Thread Starter
XJ_300
Hi Azzy,
I have checked a couple wrecking yards in the area and they have a few XJs same year as mine but I wasn't sure if I can just use a factory stock cross member once the jeep has been lifted. I'll take some pictures in the morning and will add to this thread. I also seen posts regarding the drop adjustment some Jeep owners do to the trasfercase. Is that something I also have to do?
XJ_300 is offline
post #4 of 15 Old 11-11-2013, 10:34 PM
Azzy
People drop the transfer case about an inch to cure drive-line angle issues. The stock transfer case, while weak against rocks, is fine for the stock setup. Some long and medium arm setup run the crossmember as a mounting point for control arms.
With that height, it may have had a skid plate / crossmember / control arm bracket combo... photos under it would help confirm.
Azzy is offline
post #5 of 15 Old 11-11-2013, 10:41 PM Thread Starter
XJ_300
I don't have pictures of before but I can definitely take some pictures of how it is now and post it tomorrow. Do I need to measure the lift size to decide if a drop is necessary for the transfer case?
XJ_300 is offline
post #6 of 15 Old 11-11-2013, 10:44 PM
Azzy
You need to measure your driveline angles. Some consider a drop to be a bandaid, some think they are just fine. Personally, I think a slip yoke eliminator is better, but thats getting a bit far ahead. IF yo did need / want a drop, it is a simple thing to make.
Hit up the FAQ and get to know that stuff a bit better. More people smarter than i have written about it again and again.
Azzy is offline
post #7 of 15 Old 11-11-2013, 10:54 PM Thread Starter
XJ_300
There is definitely so much to learn! But I ended up with a puzzle and not a project..
XJ_300 is offline
post #8 of 15 Old 11-12-2013, 01:11 PM Thread Starter
XJ_300
Here is some pictures of what it looks like.
XJ_300 is offline
post #9 of 15 Old 11-12-2013, 03:37 PM Thread Starter
XJ_300
posted some pictures. check them out and tell me what you think
XJ_300 is offline
post #10 of 15 Old 11-12-2013, 04:15 PM
psychoteen101
Id say somebody was trying to do a custom long arm setup. You could custom make or even modify an original crossmember to work on there. Looks like they were gonna use those 4 bolt holes on the LCA mounts to bolt up the crossmember. A little fabrication work and you can make something work. Id figure out how much lift if actually on it. Might be too high to get away with a transfer case drop.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #11 of 15 Old 11-12-2013, 04:17 PM
psychoteen101
If the lift isnt too tall and you make your own crossmember, you could build it to incorporate the drop instead of adding shims between the mount and crossmember.
post #12 of 15 Old 11-12-2013, 04:34 PM Thread Starter
XJ_300
Do I need to add a drop to the original crossmember if my lift is more than certain amount? Can you also tell me where can I measure to find out how much lift has been added to the stock height of the car?
(any link or tips to measure would be helpful)
do you have any pictures of a custom crossmember made by you or anyone you know? I just want to get some ideas before starting fabrication.
XJ_300 is offline
post #13 of 15 Old 11-12-2013, 05:04 PM
Kettles
Im 99% sure that is a Clayton Offroad long arm kit. Those square arms are a good hint, and the brackets match theirs perfectly.
Call them up, I am sure you can get a replacement crossmember. Tell them your story you might get discount.
Kit with picture
http://claytonoffroad.com/product_in...roducts_id/113
Just the 3 piece xmember
http://claytonoffroad.com/product_in...roducts_id/174
You only need the middle piece, I bet you can get just that part for cheaper.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #14 of 15 Old 11-12-2013, 05:19 PM Thread Starter
XJ_300
The brackets looks similar and thanks for the links. I am going to contact them and see if they do sell the center piece by itself.
Kit with picture
XJ_300 is offline
post #15 of 15 Old 11-12-2013, 10:51 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Yes.
Do not attempt to mount longarms to a factory cross member.
***Chris***
chris87xj is offline
lift , transfer case , transmission
