Transmission Interchange - JeepForum.com
post #1 of 5 Old 01-30-2014, 10:34 AM Thread Starter
brianrich07
Hey guys, a while back I was cruising Jeep forums and I came across a BIG interchange thread. I'm trying to figure out what aw4's will swap into my jeep. I have a 96 and im swapping the trans out. Its a 2wd and I was givin a 3in lift and a front axle. I just need a 4wd trans and tcase and some more odds and ends. If someone knows where that thread is (I've searched and searched) please post a link or if some one has done this, let me know. I found a complete 94 Xj for 600. I just wanna make sure because I know the 96 is a wierd year. Thanks in advance!!
1996 Xj 4.0 AW4 - Stock
1998 Ford Expedition Wifey's
1992 Ford F-150 4X4
brianrich07 is offline
post #2 of 5 Old 01-30-2014, 10:46 AM
skyway0018746
Dont hold me to this but I believe if you take everything from the 94 it should all work with the 96 as the trans is stand alone and both are obdI . When I did a 99 there was a few things that didn't work like the dash 4x4 light and the light on the shifter bezel . As the body harness didn't have the connectors for them.
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #3 of 5 Old 01-30-2014, 11:13 AM
Paradise XJ
1988 MJ Comanche
This pretty much covers it:
http://naxja.org/forum/showthread.php?t=1053970
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #4 of 5 Old 01-30-2014, 01:56 PM
uberxj92
1992 XJ Cherokee
All aw4 xj trannys will fit. Lol. Beyond that it gets tricky. But the 94 should work fine.
I just put in a 90 built aw4 in my 92. Had to rewire the solenoids to make it shift.
What I learned is...
87-90 renix era will fit in 91-96. Will need the 91-96 bell. And will need wiring changed in trans.
Some 96.5 are treated as 97.
The biggest problem I ran into was the tcase. I had a 95 np231hd case. Had to swap the input shaft to work on the renix trans.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 5 Old 01-30-2014, 03:24 PM Thread Starter
brianrich07
Thanks Paradise, thats exactly what I was looking for!! I know they will all physically interchange, I just don't want to get in a mess trying to MAKE something work. I would rather wait around and find one that works 100% with my jeep. I plan on making my own harness for the indicator lights, that's no big deal. Thanks for yalls help guys!!
1992 Ford F-150 4X4
