Transmission Fluid Change on 97' Cherokee - JeepForum.com
post #1 of 13 Old 12-12-2008, 06:34 AM Thread Starter
gtospeeding
I have a 97 and I want to change the trans fluid (auto). Is there a drain plug or do I have to drop the pan?
Is there an easy way to change the fluid on this kind of jeep?
gtospeeding is offline
post #2 of 13 Old 12-12-2008, 06:42 AM
Ed Rico
1997 XJ Cherokee
There is a drain plug on the AW4 but you'll have to drop the pan if you want to change the filter as well.
-Ed Rico
Ed Rico is offline
post #3 of 13 Old 12-12-2008, 06:50 AM Thread Starter
gtospeeding
-Ed Rico
whats AW4? Mine has the regular part time 4wd
if i drain the trans case (by drain plug only) how many quarts of fluid do I need to refill?
also what kind of fluid do I replace it with?
thanks
post #4 of 13 Old 12-12-2008, 07:41 AM
mhall02
The '97 Cherokee 4-speed automatic with a 4.0 is an AW-4, yep it has a drain plug. 2.5 liter 4 cylinder auto tranny is a Chrysler 3-speed that uses ATF 3. Pull the plug on the AW-4 and you get about 2.5 quarts out. Which transfer case do you have? NP 231 holds about a quart, tranny and transfer case both use Dexron/Mercon, not ATF-3 or ATF-4.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #5 of 13 Old 12-12-2008, 07:53 AM Thread Starter
gtospeeding
Im not sure what transfer case I have , how do I know?
is there a separate drain plug for the transfer case?
post #6 of 13 Old 12-12-2008, 07:58 AM
Ed Rico
1997 XJ Cherokee
Transfer case is less picky than the transmission about fluid. The 97 FSM states Dex II or ATF+3 for transfer case, later NP/NV Jeep transfer cases came with ATF+4, which is fine for '97 but not required. Most XJ owners probably use Dex III for both AW4 and transfer case which works fine and keeps things simple.
-Ed Rico
Ed Rico is offline
post #7 of 13 Old 12-12-2008, 08:02 AM
phmaris
Check this out. It will answer most of your questions regarding changing fluids in trans, transfer, & diff's.
www.4x4xplor.com/trannyservice.html
If you have part time 4WD HI & LO, and no Full time option, you have the NP231 transfer case.
phmaris is offline
post #8 of 13 Old 12-12-2008, 08:57 PM
filluptrk
If you have a Command Trac set of instructions on the headliner you have the 231. On the pan on the trans, there is a 13mm bolt at the back. My AW4 has a B&M cooler on it and drains out exactly 3qts every time. I use the Multivehicle ATF instead of Dexron. You can get it from Pennzoil, and WalMart. A bit more expensive than Dexron, but works perfect for me. I drain the trans each time I do the engine oil, cheap insurance. Phil
filluptrk is offline
post #9 of 13 Old 12-13-2008, 07:20 PM
cody4359
1987 MJ Comanche
stop by the auto parts store of ur pick and get a hayes repair manual, itll answer quite a few of your questions
cody4359 is offline
post #10 of 13 Old 12-13-2008, 08:24 PM
boknows2000
just flushed my transmission with atf+4 per chrysler service bulletin #21-014-07 dated 10-16-07 ( includes aw-4 trans )
boknows2000 is offline
post #11 of 13 Old 12-22-2008, 05:22 PM Thread Starter
gtospeeding
good post
post #12 of 13 Old 01-17-2009, 04:31 PM
TippyJeep
I want to change the filter and there's one damn bolt on the front of the pan that's blocked by the exhaust pipe. Any ideas on how to get that one out?
TippyJeep is offline
post #13 of 13 Old 01-17-2009, 04:43 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Hope it works out better for you than it did for me.
xjfever is offline
Transmission fluid change and tune up? smlducks XJ Cherokee Technical Forum 12 08-20-2009 02:41 PM
transmission fluid change mountainpoo XJ Cherokee Technical Forum 1 06-06-2008 04:52 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 05:08 PM
Transmission Fluid Change ramone XJ Cherokee Technical Forum 17 06-28-2006 11:39 AM
transmission fluid and filter change jeep xj XJ Cherokee Technical Forum 16 08-15-2005 04:08 PM
