Quantcast Transmission Cooler & Gauge Install *lots of pics* - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Transmission Cooler & Gauge Install *lots of pics*
Old 07-28-2009, 11:18 PM   #46
jjg214
Originally Posted by tphitterlude92 View Post
i will be doing this soon but i have a few questions on mounting.in tampa the temps get high so i dont really wan to have the jeep sitting in traffic for 30 mins with the ac on and then to have it overheat. would it be wise to install an electric fan on the cooler and place the cooler somewhere maybe behind the bumper?or anywhere else?
just do a quick search on how to wire your stock e-fan to a switch, that way when you hit traffic you can flip it on instantly, problem solved
its a cheap easy mod, you just need 15$ in parts/wiring from radio shack or the like.
jjg214 is offline   Reply With Quote
Old 07-29-2009, 12:02 AM   #47
phattysrt
good job bud. I too have a similar setup on my XJ. I did a couple things different though.... jegs.com has a sweet A-pillar mount for the autometer gauge i used. It fits like a glove and looks OEM. Also, for the backlighting of the gauge, i just tapped into the lighting for the heating and ac control board. So know your new gauge will now dim with all the OEM gauges. Works pretty slick.
ITS A JEEP THING... YOU WOULDN'T UNDERSTAND.
http://www.jeepforum.com/forum/f11/project-cheep-jeep-892777/
1995 XJ 4.0, AW4, 6.5 IRO Long arms, 4.56's, Auburn ECTED Dana 44 rear, SYE, 33's (SOLD)
1998 XJ 4.0 AW4... ALL STOCK... NEW PROJECT
1964 SS Chevelle, BB 396, 700r4. project in the making
phattysrt is offline   Reply With Quote
Old 07-29-2009, 10:08 AM   #48
heep of feces
would this tranny cooler thread work on a '96 cherokee? i was wanting to install one in mine but am alittle unsure if i want to tackle it myself i am wary on cutting the tranny lines that go to the radiator. who on here installed one on there '96. i bought my tranny cooler kit from NAPA btw....
100% NDN and STR8 from the REZ
heep of feces is offline   Reply With Quote
Old 07-29-2009, 11:31 AM   #49
dcorn
Probably will work exactly the same on a 96. Cutting the trans lines is no big deal. You gotta get used to that kind of work eventually if you own a cherokee.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 07-29-2009, 01:01 PM   #50
grizbait
Any reason why the next level up B&M tranny cooler wouldn't work?
You used 70268 - 13000 BTU
But that one is on back-order - and I'm thinkin this mod's gonna happen.
These are the other available B&M coolers:
70255 - 9,800 BTU
70264 - 14,400
Looks like the bigger one is 1.5" deep, vs. the .75" deep. the 14,400 BTU model is actually 1.5" shorter though..
I guess for that matter, how about the smaller one.
Anyone have opinions on that?
grizbait is offline   Reply With Quote
Old 07-29-2009, 03:56 PM   #51
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
the only thing would be more air restriction for the rest of the cooling system... There are people running huge coolers so I think any cooler would work.
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 07-30-2009, 10:25 PM   #52
GregB_00XJ
GregB_00XJ's Avatar
70255 - 9,800 BTU
70264 - 14,400
Should fit. Mine has room for a thicker one, but it will be a little tight to the AC rad.
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 08-16-2009, 09:59 AM   #53
Bubba46
phattysrt,
Do you have a part number. This mod is creeping higher on the list!
'00 XJ, 4" lift, 285/75R16 (33" dia) GoodYear Wrangler DuraTracs on 16" Moab wheels, TrueTrac + 4.56 gears, Discos, RE SF LCAs UCAs and Trackbar, RCX Drop Brackets, armor, hooks, and more...
'06 WK Limited 4.7 V-8 w/ QD-II, 245/70R17 Revos II
Bubba46 is offline   Reply With Quote
Old 08-16-2009, 12:36 PM   #54
Diamond-x
1991 XJ Cherokee
Great mounting location. I recently mounted a guage in the dash and ordered an extra temp sensor to install in the drain plug of the T/C case. This way I can use a rocker switch to monitor Trans or T/C with the same guage.
Diamond-x is offline   Reply With Quote
Old 08-16-2009, 12:46 PM   #55
tock172
Wow, that is awesome man!
1996 Mint Green XJ -Sold, 7/10
1986 BMW 535i -Sold, 12/10
2004 330i Sport
tock172 is offline   Reply With Quote
Old 09-14-2009, 12:13 AM   #56
emcvay
Just curious of how things are since bypassing the rad? I would think it would run cooler except that you've lost intake on the rad becuase of the bigger tranny cooler?
I'm going to bypass my radiator becuase like a moron I stripped the fitting in a rush -- nice -- and am wondering if it really makes much difference in engine temps (I'd think cooler) since the trans fluid no longer runs through the rad. I've got a '98 with towing package so it has the small cooler on it also -- so bypassing the radiator might actually help a little -- but maybe not.
Anyway, I'm looking for feedback there.
Got Mud? 1998 XJ with lots of goodies -- now just need new brain...
emcvay is offline   Reply With Quote
Old 10-25-2009, 08:41 AM   #57
sundownz
Very helpful post. I have been wanting to install a temp gauge and cooler on my Jeep for a while and this is a bit help.
I do have one semi-related question... can I replace the majority of the cooler line with rubber hose ? My lines are crimped and leaking at that point. So, do I need to buy all new lines or can I simply cut them behind the leak and replace that point forward to the new cooler with rubber hose ?
I can't think of a good reason why not... but perhaps someone here will know for sure.
sundownz is offline   Reply With Quote
Old 07-18-2010, 02:30 PM   #58
XmuthJ
I wouldn't use rubber hose, I'd upgrade to steel braided lines and AN fittings. I'd do that over replacing the steel lines anyday, it'd be around the same price tooo
| 1992 White XJ LaredoPARTING OUT |
|___NEW JEEP___| 98 XJ Sport | 4.0L | AW4 | 3" BB Lift | 31" BFG A/T |______________|
Originally Posted by FrumpD63
Had I bought that lil mazda I was looking at, they wouldnt have found my body until the spring.
XmuthJ is offline   Reply With Quote
Old 08-07-2010, 01:40 PM   #59
mountaincajun
cooler line routing
thanks for the thread. this information was super helpfull. I have cured my over heating problem just by bypassing the radiator and installing an aux. tranny cooler.
mountaincajun is offline   Reply With Quote
Old 08-07-2010, 06:53 PM   #60
Paradise XJ
Consarn it!!
Paradise XJ's Avatar
1990 XJ Cherokee
Originally Posted by jeepnatv4life View Post
Pix of the Gauge Hook up? The T fitting that you used.
Here's a picture of the way I hooked my gauge up.
Grounded to the end of the metal tranny line, flare fittings w/ hose barbs. All tranny lines from this point forward are rubber.
I have 2 RENIX 4.0 Jeeps
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by fedx95 View Post
Try grabbing it and yanking and see if theres any play.
Paradise XJ is offline   Reply With Quote
transmission cooler, transmission temp gauge, writeup
Glock Forum
