Quantcast Transmission Cooler & Gauge Install *lots of pics* - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Transmission Cooler & Gauge Install *lots of pics*
Old 05-20-2008, 05:01 PM   #31
jshaab2
what are those two green things next to gauge in front of trans shifter
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline   Reply With Quote
Old 06-24-2008, 09:48 PM   #32
Washington_XJ
1994 XJ Cherokee
I found this thread on google and its amazing, cheers to ya You've done exactly what I want to do with my XJ. I didnt like the idea of cutting the tranny lines for a t-connector though, wouldn't there be an easier way of making a T using the new hose from the B&M cooler kit? - btw Ive got that same cooler sitting in my garage.
Oh the galvanized T connector you used, how did you fit the cut tranny lines into it? Did you have to thread them on somehow or are they crush fittings?
Happy trails,
Xan
Washington_XJ is offline   Reply With Quote
Old 06-25-2008, 07:41 AM   #33
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
The t-fitting I used, that was included in the B&M trans temp gauge kit, uses compression fittings to connect the tubing.
http://jeepin.com/features/tranny_temp_gauge/
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 06-25-2008, 09:06 AM   #34
kennylxix
1992 XJ Cherokee
Nice writeup. There is one thing though. I would highly recommend getting a tubing cutter from an auto parts store (Under $10 for the mini one). Using any kind of friction cutter will introduce metal shavings into the fluid (not much and probably wouldn't be a problem). I just hate the idea of putting metal into my tranny when it can be avoided.
kennylxix is offline   Reply With Quote
Old 06-25-2008, 10:19 AM   #35
Washington_XJ
1994 XJ Cherokee
Ya I was thinking the same thing about the metal shavings. AWESOME WRITE UP BTW! Quick question, what size T fitting did you use? I think I might just swing by a local parts store tonight on my way home from work. It would help to know the exact name of the part so I can get it.
Old 06-25-2008, 10:42 AM   #36
Vendor
1995 XJ Cherokee
Yeah, good point, I've actually updated the write-up on my new site to recommend using a tubing cutter already. In hindsight a tubing cutter definitely would've been the best tool to use, I just didn't have one at the time. The dremel disc I used was one of the paper-thin ones, not the fiberglass ones, so any debris was more like metal dust, not shavings, not sure which would be better to have in there though, haha.
I don't know/remember what size the tubing is off the top of my head though, the B&M gauge kit came with two fittings and I just used the one that fit.
Old 06-25-2008, 03:38 PM   #37
dcorn
I think the tubing is 3/8", but don't quote me. I bought an autometer sport-comp gauge so it only came with the sensor and not the t-fitting. Wasn't hard to find at the local hardware store though.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 07-23-2009, 10:22 PM   #38
jjg214
i have the 3/8" compression T fitting but i cannot for the life of me find any adapter to get the sending unit to work. very frustrating.
jjg214 is offline   Reply With Quote
Old 07-23-2009, 11:16 PM   #39
GregB_00XJ
GregB_00XJ's Avatar
Agreed... I used the supplied fittings in my install and had no issues. I bought a tubing cutter for like $8.00 and it was awesome. Only driped out a few drops of fluid and no metal in the lines. I read this thread, mounted my cooler in nearly the same spot, and it has been awesome.
Pulled my 2700 pound trailer all over, temp never got above 170.
B&M FTW!!
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 07-25-2009, 08:24 AM   #40
ksmanimal
1985 XJ Cherokee
So everyone installs the cooler in place of, rather than along with, the cooler inside the radiator?
Is that because it's easier to do, or would using both coolers cause the tranny to run too cool?
ksmanimal is offline   Reply With Quote
Old 07-25-2009, 08:40 AM   #41
the6nightmares
Man this is a good write up, ive been meaning to do this for a while, one of those summer projects, along with so many others.
Baltimore County Jeep Club
"A squid eating dough in a polyethylene bag is fast and bulbous. Got me?"
the6nightmares is offline   Reply With Quote
Old 07-25-2009, 10:33 AM   #42
Vendor
1995 XJ Cherokee
It's not a cooler in the radiator, it's a heat exchanger, and if anything it only serves to HEAT up the transmission fluid. THAT is why a lot of us have bypassed it and that's why if you're putting a cooler inline with the radiator that you want to put it after the radiator.. Sometimes you do want this heating effect on the fluid though, like if you live in a colder climate, because it helps get the trans fluid up to proper operating temperature sooner.
Old 07-25-2009, 11:07 AM   #43
jjg214
this is how i did it
Old 07-25-2009, 11:11 AM   #44
GregB_00XJ
GregB_00XJ's Avatar
I ran mine in series with the heat exchanger in the rad. Easy to change if I need to bypass it, but I wanted to see what temps it ran with. It runs all day long near the bottom of the scale at 165 ish with it in line.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
Old 07-28-2009, 10:09 PM   #45
tphitterlude92
tphitterlude92's Avatar
2002 KJ Liberty
i will be doing this soon but i have a few questions on mounting.in tampa the temps get high so i dont really wan to have the jeep sitting in traffic for 30 mins with the ac on and then to have it overheat. would it be wise to install an electric fan on the cooler and place the cooler somewhere maybe behind the bumper?or anywhere else?
tphitterlude92 is offline   Reply With Quote
transmission cooler, transmission temp gauge, writeup
Glock Forum
