Transfer case vacuum diagram? - JeepForum.com
post #1 of 4 Old 12-03-2010, 08:44 PM Thread Starter
Phil12
1990 XJ Cherokee
I have looked all over here and on the general internet with no luck, DOES ANYONE HAVE A VACUUM DIAGRAM FOR A 1990 WITH A NP231 T/C? I find diagrams that show a switch on the front differential but as near as I can tell that does not apply.
Phil12 is offline
post #2 of 4 Old 12-04-2010, 01:55 AM
kabowabo
1988 MJ Comanche
kabowabo is offline
post #3 of 4 Old 12-04-2010, 05:53 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The vacuum switch is for the light and is mounted up under your coolant bottle.
There is a vacuum operated servo on the rear side of the front diff to engage/disengage the front axle.
My suggestion is this. The system was unreliable. It left many people without 4wd when they needed it most. In 1991 I believe the system was discontinued and they left the axle engaged all the time. Your fuel mileage will not suffer having it engaged all the time.
The axle can be permanently engaged and fixed forever with 1/2 hours work. No parts needed.
cruiser54 is offline
post #4 of 4 Old 12-04-2010, 03:36 PM
kabowabo
1988 MJ Comanche
X2. I dumped mine and installed a mid 90s D30. Non disco and a little more modern brakes.
kabowabo is offline
transfer case vacuum help Hawks91 XJ Cherokee Technical Forum 4 07-12-2009 09:50 AM
vacume diagram for 231 transfer case 90 cherokee rescue_squad XJ Cherokee Technical Forum 1 05-01-2009 07:58 PM
transfer case vacuum n_i_c_k XJ Cherokee Technical Forum 5 11-03-2008 02:06 PM
No vacuum lines to my Transfer case? CharlieMopps XJ Cherokee Technical Forum 24 09-09-2008 11:32 AM
Transfer Case Vacuum Switch? boredcherokee4l XJ Cherokee Technical Forum 3 10-09-2007 12:53 PM
