Transfer Case Linkage - JeepForum.com
post #1 of 13 Old 02-24-2011, 06:16 PM Thread Starter
sktr021
1990 XJ Cherokee
My tcase shifter linkage system is messed up, and doesn't give me very good shifts to the transfer case so I'm going to replace it. Are there any aftermarket shifter linkages, or where can I get this part? Its the part where the linkage attaches to the body on the underside
90 XJ Wagoneer LTD. 3.5" Lift on 31's.
FOR SALE-XJ Tail light housings corner lamps.
sktr021 is offline
post #2 of 13 Old 02-24-2011, 06:30 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Look up Novak shifters.
xjfever is offline
post #3 of 13 Old 02-24-2011, 06:35 PM Thread Starter
sktr021
1990 XJ Cherokee
I did just come across Novak, little pricey though.You ever used them?
Would you recommend the cable system?
sktr021 is offline
post #4 of 13 Old 02-24-2011, 09:34 PM
Rob K
1995 XJ Cherokee
If the Novak is too costly you can always repair the old linkage. I picked up a bushing kit from the dealer for about $25 and replaced them. Some grease and a linkage adjustment got mine working like new again.
Is the brass bushing messed up on yours or are you missing the entire bracket that attaches to the body?
Edit: I just realized you have a 1990 and it could be different than mine.
Rob K is offline
post #5 of 13 Old 02-24-2011, 09:51 PM Thread Starter
sktr021
1990 XJ Cherokee
Um, I'm not positive which part it is. Oh I also have a 242, I'm not sure if it has the same linkage or not. I'll tank a picture tomorrow of which part is broken
sktr021 is offline
post #6 of 13 Old 02-24-2011, 11:23 PM
DerMeister
How hard is to repair the linkage? Mine is loose, not very crisp and I can hear transfer case noise through it.
DerMeister is offline
post #7 of 13 Old 02-25-2011, 07:02 PM
Rob K
1995 XJ Cherokee
Look here for a photo of my linkage and a brief description of my repair. I had pulled the carpet and was going to remove the bracket from the body, but realized that all you have to do it pry the linkage components out of the bushings to take it all apart.
http://www.jeepforum.com/forum/f11/n...03/index2.html
Rob K is offline
post #8 of 13 Old 02-26-2011, 12:24 PM Thread Starter
sktr021
1990 XJ Cherokee
I'm pretty sure its the brass one thats wore out...thanks for the help. I'm assuming it did indeed tighten it up quite a bit? Easier shifts?
sktr021 is offline
post #9 of 13 Old 02-26-2011, 12:38 PM
Rob K
1995 XJ Cherokee
My brass bushing was real worn, but the shifting was not too bad. Shift's are smooth now.
Before the linkage repair, once in a while I would not be able to get it out of 4wd drive in the winter. Had to go forward and reverse several times before it would go back into 2wd. I still have to hit reverse sometimes to get it out of 4wd, but it comes out the first time every time, unlike before. I'm certain this has something to do with the transfer case or my shifting and not the linkage.
Rob K is offline
post #10 of 13 Old 02-26-2011, 12:48 PM Thread Starter
sktr021
1990 XJ Cherokee
I don't really have any problems shifting it just is loose...
sktr021 is offline
post #11 of 13 Old 02-27-2011, 01:08 AM
NW99XJ
I've got the very same issue on my 99 XJ with the AW4 and a 242. I did however have to do a T-case drop, and had to also install the included linkage drop bracket, which basically drops the pivot point of the armature. I cant get into 4lo without crawling under and undoing one of the bolts of the linkage drop bracket, so that the shift arm will clear. And its always a bi_ch to get back into 2WD. I was going to go the Novak cable shifter route too, but i would much rather try to rebuild or repair what I've got. I must say tho, I've been in an XJ with the cable shift and it is SOOOO buttery smoooth.
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #12 of 13 Old 02-27-2011, 09:37 AM Thread Starter
sktr021
1990 XJ Cherokee
It looks really awesome and all but I'm not sure I can justify spending that much on a shifter.
sktr021 is offline
post #13 of 13 Old 02-28-2011, 03:26 PM
NW99XJ
Novak makes their own version of the linkage style as well, for a little less in cost. Still kinda spendy tho ($157) http://www.novak-adapt.com/catalog/shifters/sk2x.htm
I'd almost like to see if some of us cant get together and figure out what they did. Find a way to rebuild these or adopt some sort of our own design to fix some of these common issues. Then offer them to other Jeepers, or post the plans for all to share. Either way, i'd like to come sort of a solution for this that doesn't involve hundreds of dollars. Has anyone heard of anybody doing this? (making their own shifter linkage or cable shifter.)
NW99XJ is offline
transfer case linkage help cloiser XJ Cherokee Technical Forum 2 12-17-2007 07:32 AM
Transfer Case Linkage crumb XJ Cherokee Technical Forum 10 04-17-2007 08:30 AM
Transfer Case Linkage ddeadserious XJ Cherokee Technical Forum 1 02-18-2007 03:41 PM
Transfer Case Linkage Bushings shaddady35 XJ Cherokee Technical Forum 5 01-18-2007 06:22 PM
transfer case linkage Ty2003K XJ Cherokee Technical Forum 4 01-22-2003 11:56 AM
