Transfer Case Leaking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Transfer Case Leaking
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 08-27-2012, 12:16 PM   #1
bataleon
So i was driving down the highway and smoke started coming from under the heep. I had just finished swapping in a new transfer case (242) and it looks like the rear output might be leaking. I replaced all of the seals and bearings and even put a new oil slinger on it while i was doing the swap, so all parts should be ok.
This struck me as odd: I noticed the smoking and immediately found the nearest parking lot. I got under and found fluid flung all around the jeeps belly and exhaust(hence the smoke) right over the rear of the tcase. i cleaned the fluid up with a rag and limped the couple miles home. when i got home there was no new fluid anywhere, and i hadn't noticed any more smoke while driving.
Thanks for your thoughts guys
bataleon is offline   Reply With Quote
Unread 08-27-2012, 12:20 PM   #2
DoctorTim
previously XJ-Tim
DoctorTim's Avatar
my guess is you didn't install a seal or gasket the correct way. if it stopped leaking for no apparent reason, that could mean theres no more oil to leak out. take out the tcase and check the seals and gaskets. also, get an SYE while you're at it.
DoctorTim is offline   Reply With Quote
Unread 08-27-2012, 12:42 PM   #3
bataleon
Haha paypal me the money to get one
I do agree that i probably lost enough fluid until no more could be ejected.
I will check to see if the seal was installed properly on the rear. That would mean im dumber than i thought, however it would be the simplest fix so i hope thats it. Time to get back outside....
Unread 08-27-2012, 12:47 PM   #4
88cheapcherokee
1988 XJ Cherokee
"I do agree that i probably lost enough fluid until no more could be ejected."
Hahahahahahahahah that's what she said.
88cheapcherokee is offline   Reply With Quote
Unread 08-27-2012, 12:49 PM   #5
Paradise XJ
1990 XJ Cherokee
Is the vent and tubing on top all connected and intact?
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by 87Warrior
A large crack can also hurt performance.
Originally Posted by jmaxey27 View Post
Yeah, the pipe hangs just fine
Paradise XJ is offline   Reply With Quote
Unread 08-27-2012, 01:08 PM   #6
rapidcycler
Swollen Member
rapidcycler's Avatar
When this happened to me, it was the o-ring on the speedo... As good a place as any to start.
rapidcycler is offline   Reply With Quote
Unread 08-27-2012, 01:16 PM   #7
bataleon
Awww man I walked right in to that one!
Yes sir. I actually have it on there with a hose clamp all torqued down and such. Any way it could be on too tight?
Absolutely. Thats right in the ballpark. I hope its just an o-ring. That'd be soooo nice...
**I forgot to mention that it is still practically full of fluid. I would say full, but i know I lost some lol
Unread 08-28-2012, 09:26 AM   #8
bataleon
Does anyone know of a part number for the o-ring? My searches aren't turning anything up
Unread 08-28-2012, 11:43 AM   #9
rapidcycler
Swollen Member
Bah, go to any auto parts store and get an o-ring of similar thickness that fits around the speedo. Take the old one, or the pieces of it, for reference. Or take the whole speedo sensor off. Mind you, I have an NP231, and it was an easy disconnect. I got one from home depot from a water faucet repair kit. ADvanced auto, track auto, pep boys. nothing special about it that I know of, except it keeps your TCase fluid IN your tcase...lol. Advanced Auto has an o-ring "pack", it has one inside of it that will work.
Did you confirm it was the o-ring? or you just gonna replace and see? Mine was visibly broken when I went back to redo the RTV on the small case housing (I thought that was the source of the leak). When I pulled the speedo sensor out, I could see that a piece of the o-ring was still in the threads. It was hard to find the source of the leak, as you know, because it splatters everywhere. I had atf splattering my muffler, running down my driveshaft, sprayed everywhere. Drove it up and down my street after hosing it off, no leak. Took it for 2 minutes on highway, atf was everywhere again.
Unread 08-28-2012, 12:45 PM   #10
bataleon
Ya i went with the guess/check method haha and replaced the o-ring today. It was not the source of the leak, however it was a great place to start. Im gonna check my breather tube and output seal once it stops raining.
Unread 08-28-2012, 03:39 PM   #11
rapidcycler
Swollen Member
yeah, output seal would make sense too. It spinning off the driveshaft everywhere. I feel for ya, it's very nerve wracking to think you're gonna run dry on tcase fluid. Post back when you find it and let me know what it was.
