Transfer case issues... - JeepForum.com
post #1 of 6 Old 05-15-2008, 11:16 PM Thread Starter
hocgreen
OK, so I finally got around to asking a few questions. I am new to the forums and I have been trolling around for the last few days just to see the advice come and go.
First, here is my beast.
Can't see the tire carrier rear bumper, but it's there
She may not look like much, but I have had her since 20K and I refuse to give her up for anyone or anything.
now the real part. 3 inch lift (rough Country) full leaf packs 3.5" swapped out the 242 (it exploded) for the 231 (cheap) and now I have a lot of drive line vibes. I am pretty sure the t case drop on the 242 is what killed it.
Would I kill the 231 if I dropped it an inch?
What is the best way to eliminate the drive vibes?
I have replaced EVERYTHING in my truck on god knows how many ends. I just wanna go with 1 3/4 shackles and spacers to get it a little higher and not have to worry about killing it. I know the SYE and DS would be the best way, but I don't have $550 to throw around.
And Last but not least, would anyone happen to have spare linkage and handle from a 98 with a 231? I can't use 4 wheel til i get one, figured there might be someone with a junker out there?
Thanks for the help in advance, love the site. Thanks for reading
hocgreen is offline
post #2 of 6 Old 05-16-2008, 01:49 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You don't necessarily have to spend $500 on a SYE. A PORC SYE and a stock front driveshaft would work and get ride of the vibes.
Another alternative sinse you have a 99 (and I assume a 96+ NP231 swapped on) you could run the RE hack-n-tap, adapter, and stock front driveshaft.
Looking at around $250-350 depending on what setup you used.
Beyond theSYE, there is no fix. You may be able to get the vibes down a little by adding teh TC drop and 3-4* of shims in the rear. You need the shims for the SYE anyway.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 6 Old 05-16-2008, 08:26 AM Thread Starter
hocgreen
well the leaf packs already came with the shims pre-installed... Don't ask me what angle because I have NO clue.
Would it be a horrible problem if I was to throw that little extra lift in there with a t case drop though? I want the extra height definitely... But I don't want it to be at the cost of the truck you know.
Yes the 231 is out of a 98.
A stock front drive shaft would work as a rear driveshaft for this scenario? Even if it was lifted 4-3/4" give or take
hocgreen is offline
post #4 of 6 Old 05-16-2008, 09:50 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
If you can't afford to put an SYE on it, you can't afford to run any more lift. Plain and simple.
You've got driveline issues that HAVE to be addressed if you want to go any higher, or heck, if you just want to stay at your current height and not screw anything else up.
Balloo's right on with his SYE recommendations.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #5 of 6 Old 05-16-2008, 06:03 PM Thread Starter
hocgreen
very much appreciated... At least i have an absolute now. Thanks. Now all I have to do is save every penny til i can afford it
hocgreen is offline
post #6 of 6 Old 05-16-2008, 07:53 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Yes, it shoudl be fine. You will need either SYE and the front shaft to work. The "cheapest/easiest" is the RE hack-n-tap. That should run approx $150 ($90 for the Hack-n-tap and $60 for the adapter).
That route involves you chopping the rear output shaft of the transfer case. You won't have to open up the case.
Check the Tech/FAQ sticky under the TRansfer case page and there are several write ups on that install.
93 Sport
Specs in Profile.
balloo93 is offline
havin issues with fuel transfer kreis870 XJ Cherokee Technical Forum 0 09-18-2009 03:54 PM
92" XJ tranny or transfer case issues hummer11 XJ Cherokee Technical Forum 2 07-17-2009 10:00 AM
Transfer Case Problems/Issues Timbo269 XJ Cherokee Technical Forum 13 02-25-2009 08:18 PM
Transfer case issues broncofire75 XJ Cherokee Technical Forum 3 02-22-2008 09:05 AM
transfer case swap issues altierior XJ Cherokee Technical Forum 5 12-20-2006 06:34 AM
