Transfer case interchangeability, What years fit 2001 - JeepForum.com
post #1 of 5 Old 09-10-2008, 07:34 AM Thread Starter
01xjltd
I have a 2001 xj that needs a NP 231 transfer case due to vibration issues.Need to know what years will work with the 01 and what diffent makes and models will fit {wrangler Liberty}.
01xjltd is offline
post #2 of 5 Old 09-10-2008, 10:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1997-2001 XJ Cherokee will bolt on. Other NP231's from the Wrangler will physically fit but may need some parts transfered from your old T-case to function properly.
Try www.car-part.com , NP231's are very easy to find.
CJ7-Tim is offline
post #3 of 5 Old 09-10-2008, 10:53 AM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Have you considered a rebuild kit?
They cost around $90 and come with all the bearings and seals.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #4 of 5 Old 09-10-2008, 01:26 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
1996-2001 XJ Cherokee would be a direct swap. Anything older than that and you'll need to change the yoke on the driveshaft. Make sure you match up the input spline count -- easiest way is to just make sure the donor vehicle used the same trans (ie: auto or manual) as yours.
TJ transfer cases will work as well, but may have different spline counts and they are clocked differently than an XJ t'case. I'm not sure if the difference in clocking is due to the bolt pattern on the t'case or on the transmission though.
I'm curious about what kind of vibration issue is necessitating replacing the transfer case though?
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #5 of 5 Old 09-10-2008, 05:06 PM
durango-bob
2006 WK
The different clocking is due to the trans, so any TJ case is a direct replacement.
durango-bob is offline
231 transfer case compatability, 92-2001? skullver XJ Cherokee Technical Forum 16 01-07-2010 01:23 PM
Interchangeability between the different years? jfman XJ Cherokee Technical Forum 16 02-01-2008 08:46 PM
Years - Interchangeability BIG1RED9 XJ Cherokee Technical Forum 6 11-16-2006 08:48 PM
91 Transfer Case Skid, will fit a 2001? RickyN29 XJ Cherokee Technical Forum 1 05-20-2006 12:18 AM
Transfer case interchangeability hawaiihomeboy XJ Cherokee Technical Forum 2 04-13-2006 06:23 PM
