Transfer Case Fluid Change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Transfer Case Fluid Change
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 08-19-2012, 02:13 PM   #1
DunmerBoy
DunmerBoy's Avatar
I'm a noob and dont know how to do it. haha how do i go about doing it?
1998 Jeep Cherokee Sport Terror the Magnificent
DunmerBoy is offline   Reply With Quote
Unread 08-19-2012, 02:17 PM   #2
Bbasso
drain and fill, rather simple.
the drain & fill plugs are the same size, but big. I forgot the size...
red- drain, blue fill.
NP231-
Bbasso is offline   Reply With Quote
Unread 08-19-2012, 02:22 PM   #3
DunmerBoy
DunmerBoy's Avatar
how much fluid goes in?
Unread 08-19-2012, 02:28 PM   #4
Bbasso
want me do the work too??
google, your new best friend
Unread 08-19-2012, 08:37 PM   #5
cruiser54
1990 MJ Comanche
REmove the fill plug first just in case. Somewhere between 2 and 3 pints of ATF.
cruiser54 is offline   Reply With Quote
Unread 08-19-2012, 09:29 PM   #6
Tdog02
My buddy (true story, not me) uses engine oil, 10W30 for his 231 on his 01 TJ. His dad is Canadian and would buy oil by the drum to get it cheaper. He used 30 weight in damn near everything. So the question is, it's not what's called for but will it do in a pinch on the trail? Would it hurt to run it everyday? Just asking?!?
2002 TJ Sport RED Jeep #648 30-44/3.73
Trail rider and DD
I need some red full size doors for a TJ
Tdog02 is offline   Reply With Quote
Unread 08-20-2012, 07:43 AM   #7
CCKen
DunmerBoy,
Here's some recommendations, with photos:
Pic of the recommended tooling you'll need. The drain/refill plugs in your '98, if original OEM, are internal wrenching 10 MM hex plugs. I show a 10 MM hex bit with a 1/2" breaker bar to remove the plugs. If the plugs have never been removed be prepared for a struggle. You may have to use an impact wrench to get them out. The pump showm is great for pumping the fluid into the TC. It is available at Advance and O'reilly Auto Parts. I use a 19 MM box end wrench to install the new plugs. Shown is Valvoline Max Life DEX MERC ATF (which I use in my AW4) but I normally just use Advance Auto Parts DEXIII/MERC ATF in my NV242. You'll need three pints of ATF (two quarts).
I recommend replacing the 10 MM hex plugs with flanged external hex plugs. These are 19 MM Wrench head plugs from NAPA. I use the 19 MM wrench to install them. The part number of the plugs are in this pic:
Like has been said, remove the FILL plug first, then the drain plug. If you remove the drain plug first and drain all the fluid and then can't get the FILL plug out you will have fun trying to refill the TC. I have heard of refilling it through the vent hose fitting...not fun.
When you drain the TC examine the drained fluid. Check for metal suspended in the fluid (indicates advanced wear inside the TC). Also check the color of the fluid; milky fluid means the previous owner never changed the fluid (and probably doesn't wipe his arse either). If any of these conditions exist, I recommend filling the TC and driving your Jeep around for a bit then drain and refill it. Check the drained fluid again. If it doesn't look clear, do it again. I know, all this ATF gets expensive but clean ATF in your TC is the heart of its longivity.
CCKen is offline   Reply With Quote
Unread 08-20-2012, 09:11 AM   #8
crzmn1
1994 XJ Cherokee
i have a question on the plugs mine are big bolts like 1 1/16 big is that a factory or some one elses idea
crzmn1 is offline   Reply With Quote
Unread 08-20-2012, 11:06 AM   #9
CCKen
The earlier XJ's, like yours, had 30 MM wrench size plugs. The 19 MM plugs will take the place of your drain/refill plugs okay: both are 22 MM threads.
