Quantcast Which transfer case do I have? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Which transfer case do I have?
Old 01-21-2007, 01:32 PM   #1
crna2011
I know that I should be able to look at the back of the transfer case and see the tag but there is a problem with that. I have a 1993 Cherokee Sport. When someone else was driving it the drive shaft from the transfer case to the front diff and about 2/3rds of the transfer case broke off. Completely missing from the vehicle. This was on the freeway about a month ago. They towed it and cannot remember what section of the road they were on or I would go look for it. Anyway, I need to replace the transfer case and the front drive shaft. The part of the transfer case that should have the tag is laying along the freeway somewhere. Is there any other way to tell if it is a 231 or a 242? I was hoping to pull the old one and replace it all at the same time so I am hoping that I can tell which case while it is still in the vehicle. Any suggestions?
Thanks
crna2011 is offline   Reply With Quote
Old 01-21-2007, 01:37 PM   #2
JeepFreak91
Thanks
what does the 4wd selector say in the cab? 2wd-4wdhi-etc.?
JeepFreak91 is offline   Reply With Quote
Old 01-21-2007, 01:37 PM   #3
Steamer98
When selecting a 4wd function, do you have a "full time" option?
98 XJ Limited
Stock XJ tire carrier for sale
http://www.jeepforum.com/forum/showthread.php?t=424930
Steamer98 is offline   Reply With Quote
Old 01-21-2007, 01:48 PM   #4
sharpie
German car snob
sharpie's Avatar
1999
the MOST simple way to find out what you have: Look at your 4wd shifter, does it say:
2HI
4HI
N
....4LO
If it shows up like that, you have a 231.
- Brian
Klein Concept and Design
KCD Website
Follow us on Facebook!
XJ Writeups:
| DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE
sharpie is offline   Reply With Quote
Old 01-22-2007, 09:25 AM   #5
crna2011
The selector looks just like that.
2H
4H
N
4L
the slot jogs to the right a little between neutral and 4H I think. But those are certainly the four choices on the selector.
Here is another newbie question, is there a difference between a 231, NP231, and an NP231J? Do I have to know the right number of splines to buy the new one?
Old 03-07-2009, 11:31 AM   #6
willcraft
1992 XJ Cherokee
I would like to have whats left of that t/case if you still have it
willcraft is offline   Reply With Quote
Glock Forum
