transfer case chain - JeepForum.com
post #1 of 4 Old 02-13-2013, 11:34 AM Thread Starter
btltnk
1995 XJ Cherokee
transfer case chain
Is it possible to replace the chain on a 242 with the t-case still on the jeep? This is on my 91 briarwood. Do you also have to buy the rebuild kit and replace all the seals and other things that come in it or can I just take it apart and only replace the chain?
btltnk is offline
post #2 of 4 Old 02-13-2013, 11:50 AM
MJR
MJR's Avatar
1988
You could but you will have to take the front output gear (inside the case) off to do it. Usually just easier on a bench especially playing with the oil pump. You'll need a tube of RTV and at least the rear output seal.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 4 Old 02-13-2013, 12:07 PM
CCKen
CCKen's Avatar
Here's a photo tutorial that will get you to the chain. There's Youtube vids on changing the chain, which you will need to look up.
http://mallcrawlin.com/forum/showthr...n-of-the-NV242
CCKen is offline
post #4 of 4 Old 02-13-2013, 05:08 PM
miceanic
1990 XJ Cherokee
Did mine last weekend and it wasn't as bad as I thought, left the case in the xj. You need the right snap ring pliers and a tube of rtv then the rear seal like already mentioned. Do you have a SYE? If so make sure you get the correct seal.
miceanic is offline
