Quantcast Which Transfer case is this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Which Transfer case is this?
Black Magic Brakes - 5% Off, No Minimum Purchase RequiredOfficial Chassis Saver Rust Preventive Truck & Auto UnIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 09-30-2007, 07:36 PM   #1
4.0H.O.XJ
And is it any good?
It says "231 J" under the New Process crest on the tag...........I thought 96's had a 242 or something.
Is this T-case any good?
4.0H.O.XJ is offline   Reply With Quote
Old 09-30-2007, 07:39 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That's a Jeep NP231 or Conmmand trac. It's rated for more torque load than a NP242, but doesn't have the full time option.
LOTS of aftermarket support for it in everything from SYE choices, wide chain kits, overhaul kits, and 4 to 1 kits.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 09-30-2007, 07:41 PM   #3
4.0H.O.XJ
Thanks balloo. I gotta change the rear seal on it, and I wanted to be sure before I blindly started buying seals. MINOR leak. Do you think I should wait until I do my SYE?
Thx agan,
Tom
Old 09-30-2007, 07:44 PM   #4
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Count the rear input gear splines and figure out if it's 21 or 23 splines. If it has a year written on it or is identified as what year, it will make it easier to determine compatability.
Seal shouold eb cheap and easy to replace, but make REAL sure it's just time that broke it down. Check the output shaft bearing and make sure the shaft doesn't have any side to side or up down play in it.
93 Sport
Specs in Profile.
Old 09-30-2007, 09:32 PM   #5
dudedawg
1993 XJ Cherokee
I have a 93 with a NV or NP 242 comand trac. The 231 is a select trac that I have in my 98 TJ.
dudedawg is offline   Reply With Quote
Old 09-30-2007, 09:34 PM   #6
xhavier_5478
1992 XJ Cherokee
They didn't put a Sele-trac in a wrangler.
1992 Jeep Cherokee Limited
Proud Michigan Jeeper
xhavier_5478 is offline   Reply With Quote
Old 09-30-2007, 09:36 PM   #7
dudedawg
1993 XJ Cherokee
its a 231
What ever
Old 09-30-2007, 09:39 PM   #8
dudedawg
1993 XJ Cherokee
my 93 cherokee has a comand trac 242
i have read it on the visor. SYE's are rare. the 231 is a select trac.
Old 09-30-2007, 09:44 PM   #9
xhavier_5478
1992 XJ Cherokee
http://www.offroaders.com/tech/jeep/transfer-cases-factory-np242.htm
Usage
The NP242 is used in Grand Cherokees (ZJ) and Cherokees (XJ).
Also known as the Selec-Trac transfer case.
OP Listen to Balloo93 he knows what he is talking about.
Old 09-30-2007, 10:50 PM   #10
mrboom
1995 XJ Cherokee
Originally Posted by dudedawg
SYE's are rare..
Huh?.......
My Jeep Hates Me..
95 Sport. 4.5 homebrew lift.. *Bastard Pack and loving it*
Everytime a Commander Roles off the Lot, a Cherokee Dies.
mrboom is offline   Reply With Quote
Old 10-01-2007, 08:01 AM   #11
CharBroiled
selec tracs do have some drawbacks as they are slightly weaker when youre doing hardcore wheeling and they sometimes are harder to switch from mode to mode but I wouldnt trade it for the world as mine is a 98% on road rig. in full time they are great in snow and rain and as soon as the snow hits the ground I just leave it in full time for weeks on end. much better handling than part time as they dont understeer around corners and twisty roads. its about the same as all wheel drive. if its really deep snow or off road trails I put it in part time. kinda the best of both worlds.
other drawbacks are less aftermarket support but it is what it is.
if youre a hardcore wheeler the command track is better but its up to you.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling
[COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street
CharBroiled is offline   Reply With Quote
Glock Forum
