Quantcast transfer case - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > transfer case
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 01-17-2007, 06:17 PM   #1
blackwaterjeep
transfer case
ok i have been wheeling since i have had my drivers license. i had a chevy pickup, but totalled it out on my way to go wheeling. so i got a 4wd cherokee to start on and build it up. i just ordered a 3inch lift. with a one inch transfercase drop. will i have to lengthn the shifter on the 4wd by any chance, or will it be fine, and just sit lower in the floor? thanks
blackwaterjeep is offline   Reply With Quote
Old 01-17-2007, 06:36 PM   #2
olds442
youll be fine
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 01-17-2007, 06:43 PM   #3
Jeds Sr.
Things don't work like that with a unibody.........right.
Jeds Sr. is offline   Reply With Quote
Old 01-17-2007, 08:18 PM   #4
blackwaterjeep
thanks that is all i needed. i know its a unibody, i am doing a suspension lift, but dropping the tcase will drop the 4wd shift handle i believe
len. black water 4wheelers
Old 01-17-2007, 08:29 PM   #5
iwishihad1
nope..1 inch drop and the shifter doesn't move
iwishihad1 is offline   Reply With Quote
Old 01-18-2007, 02:14 PM   #6
TheNerd
At the most you will have to adjust the linkage under the jeep if you find yourself popping out of gear or unable to get it all the way into 4lo.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline   Reply With Quote
Glock Forum
