Transfer Case??? - JeepForum.com
post #1 of 6 Old 03-12-2011, 11:55 AM Thread Starter
brimik
Transfer Case???
When I turn in 4wd the front end binds and lurches. Changed the u joints and that didnít help and it only happens in 4wd. Do I have bad transfer case?
01 XJ NP231
brimik is offline
post #2 of 6 Old 03-12-2011, 12:01 PM
jetboy287
What kind of surface are you trying to drive on? If it's a paved surface then that's normal and you'll end up messing something up if you keep doing it.
jetboy287 is online now
post #3 of 6 Old 03-12-2011, 12:31 PM Thread Starter
brimik
We had a snow storm two weeks ago and it still happen on snow covered roads. I have put 218k on Jeep and this issue has come about within the last month.
brimik is offline
post #4 of 6 Old 03-12-2011, 12:59 PM
keepishop
1989 XJ Cherokee
That's normal. 231 4wd is not made for uturns.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #5 of 6 Old 03-12-2011, 01:31 PM Thread Starter
brimik
I realize sharp turns will cause a binding effect but Iím not able to turn from a main road onto a side street.
brimik is offline
post #6 of 6 Old 03-12-2011, 01:36 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the 4x4 works normally on non-pavement surfaces, the T-case is fine.
I flip 4x4 on and off as needed when driving on pavement in snowy/icy conditions. When turning in 4x4 some binding of the front axle is to be expected.
CJ7-Tim is offline
Transfer case ? Bigthinker XJ Cherokee Technical Forum 9 06-04-2009 06:42 AM
NP 231 transfer case............. Maybe XJ Cherokee Technical Forum 8 04-15-2009 07:38 PM
Transfer case B_carney XJ Cherokee Technical Forum 1 03-05-2009 09:22 PM
which transfer case? joshpiela XJ Cherokee Technical Forum 3 06-24-2006 07:58 AM
Transfer case rotor XJ Cherokee Technical Forum 4 12-02-2003 07:29 AM
