Trans won't shift in to 3rd Gear when hot - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Trans won't shift in to 3rd Gear when hot
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 03-13-2002, 12:35 PM   #1
chrism73
Post Trans won't shift in to 3rd Gear when hot
I have a 85' xj with 4 cylender And Auto Trans.
My problem is when I drive in town it is fine. But when I try to go out of town just 8mi. . When I stop after the drive and go agian it won't go in to 3er gear. But if I shut it off for about 10 min. It will go into 3rd gear. Like it is overheating can that be due to pluged trans. filter or something else..
thanks for all of the help that you can give
chrism73 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2002, 02:42 PM   #2
Daren
Post
Chris had a similar issue with a different Chrysler tranny in an Avenger. As much as it pains me to say my friend, the only thing that happened after that was the replacement of the entire thing. She left me stranded. Stupid thing was only three years old. How long has it been doing this?
1988 Jeep Cherokee 4.0. A work in progress, but I love it more than one could ever know.
Daren is offline   Reply With Quote Quick reply to this message
Unread 03-13-2002, 04:06 PM   #3
chrism73
Post
About 3 months it has a small trany. leak
So I'd put some stop leak in it every now and then. I was wondering if that stuff could have pluged the filter up
Unread 03-13-2002, 08:06 PM   #4
CB89XJ
Post
If it was designed for Trannys it shouldn't clog it up. You may want to just look into flushing the tranny and filter change, or maybe a tranny cooler.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline   Reply With Quote Quick reply to this message
Unread 03-14-2002, 03:52 PM   #5
84wagoneer
Question
Sounds like your computer is putting the tranny into limp mode. Check your codes and see what is causing a problem. Sounds like a sensor is dead or going dead. My wifes van did this for several months until I isolated a bad wire that was shorting every now and then causing an error to the computer. Worth a look. Good luck.
84 Wagoneer, 207k miles with 4 angry mice under the hood. Uniden CB, Kenwood 2-meter. Tow Hooks, front skid plate. Not pretty, but it runs well, goes where I want it and it's paid for.
84wagoneer is offline   Reply With Quote Quick reply to this message
