Trans won't shift in to 3rd Gear when hot - JeepForum.com
post #1 of 5 Old 03-13-2002, 12:35 PM Thread Starter
chrism73
Post Trans won't shift in to 3rd Gear when hot
I have a 85' xj with 4 cylender And Auto Trans.
My problem is when I drive in town it is fine. But when I try to go out of town just 8mi. . When I stop after the drive and go agian it won't go in to 3er gear. But if I shut it off for about 10 min. It will go into 3rd gear. Like it is overheating can that be due to pluged trans. filter or something else..
thanks for all of the help that you can give
chrism73 is offline
post #2 of 5 Old 03-13-2002, 02:42 PM
Daren
Post
Chris had a similar issue with a different Chrysler tranny in an Avenger. As much as it pains me to say my friend, the only thing that happened after that was the replacement of the entire thing. She left me stranded. Stupid thing was only three years old. How long has it been doing this?
1988 Jeep Cherokee 4.0. A work in progress, but I love it more than one could ever know.
Daren is offline
post #3 of 5 Old 03-13-2002, 04:06 PM Thread Starter
chrism73
Post
About 3 months it has a small trany. leak
So I'd put some stop leak in it every now and then. I was wondering if that stuff could have pluged the filter up
chrism73 is offline
post #4 of 5 Old 03-13-2002, 08:06 PM
CB89XJ
Post
If it was designed for Trannys it shouldn't clog it up. You may want to just look into flushing the tranny and filter change, or maybe a tranny cooler.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #5 of 5 Old 03-14-2002, 03:52 PM
84wagoneer
Question
Sounds like your computer is putting the tranny into limp mode. Check your codes and see what is causing a problem. Sounds like a sensor is dead or going dead. My wifes van did this for several months until I isolated a bad wire that was shorting every now and then causing an error to the computer. Worth a look. Good luck.
84 Wagoneer, 207k miles with 4 angry mice under the hood. Uniden CB, Kenwood 2-meter. Tow Hooks, front skid plate. Not pretty, but it runs well, goes where I want it and it's paid for.
84wagoneer is offline
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 12:51 PM
'90 XJ Auto trans shift problem - need advise theboilermaker XJ Cherokee Technical Forum 1 10-09-2006 07:46 PM
Replaced Trans Seal and seems to shift Hard arl37 XJ Cherokee Technical Forum 3 05-21-2006 10:11 PM
auto trans won't shift into final drive rookie_j XJ Cherokee Technical Forum 10 10-24-2005 11:16 AM
shift kit for AW4 auto trans electriczipper XJ Cherokee Technical Forum 10 06-08-2004 07:10 PM
