i've got a 90 with the aw4 trans (comfort/power switch) . what all is involved in swaping to a 91-up trans (no- switch) ?
or someone tell me whats up with my trans .
today wheelin it started , it works great till you get into a hard pull then it just starts stalling the converter . it does it in overdrive and drive . but if you pull it into low it starts pulling just like it should , then you can shift to drive and it works fine till you get to a hard pull . it doesn't really seem to be slipping . more like the conveters got a huge stall . (it still pulls) just not fast .
trans gone ?
solinoid problem ?
something else ?
i can get a 94 model trans/t-case for dirt cheap. if ya'll think its the trans going south i'll try the swap . if its not too hard .
