Tranny fluid radiator hose keeps blowing off? - JeepForum.com
post #1 of 5 Old 01-15-2009, 08:11 PM Thread Starter
DeepJeep
About 3 weeks ago the transmission fluid hose running to the radiator came off the little barb and all of the fluid leaked out. I got a new hose clamp that actually fit, slid the hose all the way on and tightened up the hose well. Today when I left school it started to come out of gear and then I could smell the fluid and sure enough I knew the hose came off again. The fluid is leaking no where else and isnt coming threw the hose anywhere but for some reason it keeps coming off. Do I just have **** for luck or is there a pressure or heating build up of some sort? The fluid is clean the the Jeep was still fairly cold.
DeepJeep is offline
post #2 of 5 Old 01-15-2009, 08:19 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Cut the hose back some and put he clamp back on. The hose will soften with time and stretch enough that it won't hold the barb like it once did.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 01-15-2009, 08:26 PM Thread Starter
DeepJeep
That might do it. There isnt much slack at all if any on the hose but Ill check it out tomorrow.
DeepJeep is offline
post #4 of 5 Old 01-15-2009, 09:21 PM
diskman_1
1992 XJ Cherokee
On my old Charger I had to run 4 hose clamps per end. Total of 16. Ohh Yeah..
Also seconding to cut the end off. You *might* just want to replace the line with fresh stuff anyways.
diskman_1 is offline
post #5 of 5 Old 01-15-2009, 09:36 PM
conrasm
conrasm's Avatar
I don't know how much pressure a tranny can make, but could the heat exchanger in the rad be clogged causing it to blow off? Just something else to consider. I would try at least double clamping it.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
What causes hose to come off radiator? mmscheeler XJ Cherokee Technical Forum 12 02-06-2010 07:05 PM
Transmision fluid blowing past seals Mighty Thor XJ Cherokee Technical Forum 3 12-21-2009 06:19 PM
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro XJ Cherokee Technical Forum 2 08-13-2009 09:49 PM
Leaking tranny fluid from lower radiator trans cooler. EnderUSAF XJ Cherokee Technical Forum 3 03-19-2008 09:11 AM
radiator tranny hose quick disconnect rockodilered XJ Cherokee Technical Forum 14 10-21-2005 06:43 PM
