Quantcast Tranny cooler questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Tranny cooler questions
Old 07-30-2005, 09:03 PM   #1
XJ-NoDough
Okay so I'm thinking it's getting to be time to save up for a tranny cooler. Any recommendations as to brand, capacity, dimensions, and any of these things?
[SIZE=2][B][COLOR=Blue][B]My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded[/B][/COLOR]
[COLOR=Red][B]4L Selec-trac[/B][/COLOR]
[COLOR=White][B]Automatic[/B][/COLOR]
[COLOR=Red][B]3"-4.5"ish Homebrew lift[/B][/COLOR]
[COLOR=White][B]16x8 MB Motoring Rockers[/B][/COLOR]
[COLOR=Red][B]265/75R16(31[SIZE="1"]ish[/SIZE]"X10.4") Goodyear Wrangler M/TRs[/B][/COLOR]
[COLOR=White][B]Trimmed w/ Bushwackers[/B][/COLOR]
[COLOR=Red][B]Stock 3:55 gears[/B][/COLOR][/B][/SIZE]
[B][COLOR=White]sans big audio[/COLOR][/B]
[B][COLOR=Red]Homebrew intake w/cone filter[/COLOR][/B]
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline   Reply With Quote
Old 07-30-2005, 11:35 PM   #2
jlayne
get the biggest one you can find (and fit in your jeep) and plumb it in before the radiator cooler, if you leave it hooked up it will keep your tranny from getting too cold in the winter (yes they can get to cold)... if you want to go cooler you could mount a 10 inch electric fan on a switch on the cooler that could be used when wheeling or towing and shut off in the winter or normal driving to avoid over cooling your tranny
98 TJ 4 Banger, lift, tires... blah blah blah (wifes DD)
86 XJ 2.8 V6, 4 barrel carb, lift, tires... blah blah blah
61 CJ6 4 Banger, PTO winch, Stock, Rusty
00 F250 Diesel 4x4, To the trail hauler.
Several others. Mostly Fords.
jlayne is offline   Reply With Quote
Old 07-31-2005, 03:14 AM   #3
Trippe
1997 XJ Cherokee
Location: Tampa: When Hell is just not hot enough for you!
i used the b&m supercooler tranny cooler model 70268 and it has been awesome...its rated for 19000lb/gvw..that was big enough for me...and it has a built in bypass so that the oil is only cooled when it needs to be...jason from jeepin.com did a writeup on the install..thats what i used..good luck..
1997 Green XJ 2 door
*RIP*
GREEN JEEP CLUB MEMBER #130
Parrothead Jeeper Union Member #1
Trippe is offline   Reply With Quote
Glock Forum
