Tranny cooler line repair... - JeepForum.com
post #1 of 5 Old 03-18-2009, 03:57 PM Thread Starter
lasvegasoffroad
1991 XJ Cherokee
So the oil line from the tranny to the cooler is leaking where the crimmped connection is. The spot where the metal tubing goes to rubber hosing. The local Vatozone here can order one of the lines I need, but not the other line. My question is should I hunt down all the lines, which could almost be around $100, or should I take a flare tool and cut the crimp off, flare the hard line and use hose clamps. Ive heard it will work....Any body do this or have suggestions?
lasvegasoffroad is offline
post #2 of 5 Old 03-18-2009, 04:11 PM
justanotherjpr
Double hose clamp and transmission cooler line FTW! Don't use regular hose. I got some stuff at Napa rated for transmission fluid. 4000PSI rated and able to handle the heat and fluid.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 5 Old 03-18-2009, 04:17 PM
XscottJ
cut,flare , double hose clamp, that's what I did. All my lines where leaking I have no problems now knock on wood!!!! Good Luck
!!Just Empty Every Pocket!!
XscottJ is offline
post #4 of 5 Old 03-18-2009, 04:55 PM Thread Starter
lasvegasoffroad
1991 XJ Cherokee
Thanks I was sort of hesitant because me and a buddy burned down a 1500 he bought when the cooler line came undone. The line was fixed the way I want to fix it, just no flare. I found out that ATF flashpoint is the same temprature as a Chevy 350 normal operating temprature. So flare it with two hose clamps. Im not going to completely remove the rubber hose so Ill jsut cut off the crimp and flare the old line. If I had to replace both ends of the same line, then i would have to get some rubber hosing specific for hi-temp and pressure oil?
post #5 of 5 Old 03-18-2009, 06:36 PM
tangofox007
I bought two new lines from rockauto.com for around $45.
It's called transmission cooler hose. Perfect for the application in question.
tangofox007 is offline
tranny cooler line Codyxbell XJ Cherokee Technical Forum 2 01-11-2010 04:56 PM
Need tranny cooler line whoops XJ Cherokee Technical Forum 0 12-14-2009 08:17 PM
Tranny Cooler Line mfinkler XJ Cherokee Technical Forum 5 02-14-2007 06:10 PM
Tranny cooler line dudeinajp XJ Cherokee Technical Forum 1 12-27-2006 08:58 PM
Tranny cooler line leaking Rescue XJ XJ Cherokee Technical Forum 10 05-18-2005 01:33 PM
