Quantcast Tranny Cooler and Gauge Questions - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Tranny Cooler and Gauge Questions
Old 12-22-2007, 06:51 PM   #16
SmrtJustin
I think it would be a good idea. I also like the B&M cooler because of the temperature bypass when the fluid is cold. On my Jeep I put the guage sending unit on the send line. That way I know what temperature the transmission is actually running at, not what temperature the fluid is returning to it after it came from the cooler. You could put the cooler on the side of the radiator with the aux electric fan, wire up a manual switch to the fan, and that way when you notice that the trans temp is rising, flip the switch.
1999 Cherokee Classic
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
OME CS035RA Heavy Load Rear Leafs (~3.25")
RE 1334 Front Spacers (~2.5")
P.O.R.C. HD SYE
30x9.5 General Grabber AT2s
B&M SuperCooler 70255 and Temp Guage
SmrtJustin is offline   Reply With Quote
Old 12-22-2007, 07:02 PM   #17
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I did the same, so I know how hot the fluid is before cooling. That B&M dropped the temps by about 20* and that's in the summer.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 12-22-2007, 07:05 PM   #18
dudeinatj
Originally Posted by crosbike3688
No...............
I overheated my transmission very bad over the summer and invested in a gauge and cooler. This is what i purchased and I am very happy with it.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D3357&N=700+ 0&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG4962A&N=70 0+0&autoview=sku
you'll also need this to hook up the gauge:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D2286&N=700+ 302498+115&autoview=sku
dudeinatj is offline   Reply With Quote
Old 12-22-2007, 07:16 PM   #19
lost honda pro
1997 XJ Cherokee
i'm getting the same B&M supercooler jason used, and installing it in a week or so. i will do a writeup just cuz i always do writeups.
and this new line of autometer gauges (the 'GS' series) looks like it should match the OE XJ gauges (97-01, at least) when its lit up at night...
lost honda pro is offline   Reply With Quote
Old 12-22-2007, 07:24 PM   #20
SmrtJustin
You could always buy another sending unit (and the fittings) and put one in each line. Then use a SPDT switch to switch the guage from reading one to the other.
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
P.O.R.C. HD SYE
Old 12-22-2007, 07:48 PM   #21
crosbike3688
1994 XJ Cherokee
Originally Posted by dude in an xj
if u paid 36 bucks for that you are retarded. go to a hardware store and purchase a fitting for the most 4 bucks.
[U]1994 Jeep Cherokee[/U]
SYE,6" RE with tnt y-link long arms,
33x12.5 BFG Mud Terrains, Nates 4x4 custom winch bumper
[QUOTE=ktmracer419]either way thats ridiculously peepee enlargingly tall.[/QUOTE]
crosbike3688 is offline   Reply With Quote
Old 12-22-2007, 08:42 PM   #22
severous01
i guess everyone stopped reading after the first paragraph.
if i were you, i'd shroud it and put a fan on it. then the mod would be worth wile...and you can get some aluminum sheet from autozone, a rivot gun and some wooden dowels to shape it. i figure a 18000gvwr cooler with 3 90mm fans would work wonders. and locate it high so water stays out.
the cooler is useless WHEN THERE'S NO AIR FLOW ACROSS IT...and it doesnt have a radiator shroud or it's own fan...not for 50 bucks. the ONLY cooler i'd get is one with a built in fan. the only one i know of is B&M's unit, and it's 200 bucks for a 4" x 4" square with a 3" computer fan on it...wooptie doo...i'm not paying 200 bucks for a mini-me radiator and a $2 computer fan.
any way, back to the point...if you're crawling, like you would be over rocks or in mud...then there will be no air flow across the cooler...and i dont care how big it is or how long it takes to cross...it's not long enough to SUFFICIENTLY cool anything. you may drop 5*f but what's that do, 4k life miles out of the trans??? ah...worth it.
for those who dont read the whole post...here's the wrap up:
cooler with a shroud and fans, worth it....no shroud and no fans, dont even bother.
1994 jeep cherokee, xj, 3" rough country springs / bilstein 5100's, 31" tires with trimmed fenders, aussie locked front diff, herculined ext, hella FF75 driving lights on factory fog location
[COLOR="Lime"]soon to be[/COLOR] 4.11 gear and and a ford 8.8 LSD rear and herc'd interior
severous01 is offline   Reply With Quote
Old 12-22-2007, 10:29 PM   #23
lost honda pro
1997 XJ Cherokee
did you never consider the fact that the XJ radiator, with little / no airflow, running a trail, sits @ AT LEAST 210 degrees, if not higher? and when fluid leaving a trans cycles through a 210*+ radiator, it gets heated up, instead of cooled?
therefore, if your trans is running at 180*, and the fluid cycles through a cooler (assuming no fan / shroud ), it will AT LEAST not gain any heat. then you add the fact that because a cooler is sitting in front of the radiator, and the radiator has a shroud / fan, there will be some air flowing past it, dropping temps even more.
so you say its a 5* drop - i say, even if there's NO HEAT EXCHANGE AT ALL (which is impossible unless its 180* out) you're dropping your trans temps ~30*. is that worth $50? any day of the week.
Old 12-22-2007, 10:35 PM   #24
karacer
1993 XJ Cherokee
I run the same setup as Jason's write-up.
Not going to argue semantics here, but I have the cooler in front of the Auxillary fan. The electric fan is wired into a switch as well as the factory plug.
This has worked very well in the 3 years its in. First trip out was to Paragon in August, 90+ degree day. Using the elec. fan more than not, the trans temp went to the yellow area,but never the red that day.
93 xj, AW4, 170,000 miles and still going strong.
karacer is offline   Reply With Quote
Old 12-24-2007, 09:01 AM   #25
bmyohn
Youngin'
bmyohn's Avatar
thanks for the replies guys
can some one explain the switch to the aux. fan for me, i guess im not 100% sure about it
i still havent bought a tranny cooler yet, but i will be changing out the fluid this week some point, so it may be a good time to pick one up.
any more tips would be greatly appreciated
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 12-24-2007, 09:19 AM   #26
dudeinatj
here ya go...
http://www.projectxj.com/mods/stocker/fan.switch.htm
Old 12-24-2007, 10:00 AM   #27
karacer
1993 XJ Cherokee
Almost the same thing I did.
Old 12-24-2007, 10:57 AM   #28
red_01_xj
XJ Cherokee
I have the B&M and love it now...but right away it gave me a headach because i routed my hoses goofy and it caused one of them to get hit by the fan blade...so be careful where you route them but otherwise it works great and easy to install
2000 RED XJ
4.5" RE Super Flex, Mono Tubes, 31" BFG AT, WJ seats Front and rear, Boxed Rocker panels with Rails, Upcountry Junkyard Special, homemade front bumper, C4x4 rear bumper and swing out, low profile light bar, jks disconects, farmboy tail lights lebaron hood vents, teraflex sye, Dana 30 HP with factory 4.56 disco converted to solid shafts, with powertrax, Dana 44 with detriot true trac with 4.56 and ZJ disc brakes...and the best part is all of my major mods are used
Ebay items http://motors.search.ebay.com/_W0QQsassZred01xj
red_01_xj is offline   Reply With Quote
Old 12-24-2007, 11:49 AM   #29
bmyohn
Youngin'
bmyohn's Avatar
awesome...thanks for the link
so i guess, u just flip the switch when u hit the trail head or something.
when do u turn it on? when it gets a little warm, but not warm enough to trigger the fan to run?
"The Tow Rig"
1988 Jeep Comanche
Old 12-24-2007, 12:41 PM   #30
CharBroiled
I didnt see an inline fuse in that howto. put one as close to the battery as possible on the B+ wire. use whatever rating the regular aux fan fuse is.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling
[COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street
CharBroiled is offline   Reply With Quote
Glock Forum
