Tranfer Case sector shaft seal - JeepForum.com
post #1 of 5 Old 03-17-2006, 05:41 PM Thread Starter
crocket32
My sector shaft seal is leaking on my 242 transfer case. It is the seal that the shaft to select 4hi , 4low etc goes through. Does anyone know if this seal can be changed with the tranfer case still in the vehicle? Any help is appreciated.
crocket32 is offline
post #2 of 5 Old 03-17-2006, 11:56 PM
jeepsterguy
2011 WK
Got some good news and some bad news.
The good news is that the problem is an "O" ring around the shaft. Replace the "O" ring, problem solved. Now for the bad news.
I looked in the manual and they show that to replace the "O" ring you have to open up the case. Working inside the case, you remove the shaft, a bushing and the seal, reverse to install. That's the manual, in real life it would be nice if you can use a pick tool to pry out the old and then push a new in its place. If anybody has done it, tell us.
Good luck.
jeepsterguy is offline
post #3 of 5 Old 03-19-2006, 07:58 AM Thread Starter
crocket32
yeah I read tha in the manual as well. I was hoping someone had done it the way you described without dropping and splitting the case. If anyone has please let me know.
Dave
post #4 of 5 Old 03-20-2006, 01:00 PM Thread Starter
crocket32
bumpity bump bump
post #5 of 5 Old 08-17-2013, 02:19 PM
Shekels
so this thread is a little old,... But i ran into the same problem and was not about to split my case open to replace that stupid oring.
i pried out the plastic retainer and then used a sewing needle thing to get the oring out, i just stabbed the oring with the needle and didnt even scratch the case at all. it was my last ditch effort that ended up working amazingly well.
Shekels is offline
Replacing sector shaft oring blk98XJ XJ Cherokee Technical Forum 0 07-15-2009 11:57 AM
Help with Tranfer Case please jpluff2 XJ Cherokee Technical Forum 2 02-24-2009 11:48 AM
tranfer case jshaab2 XJ Cherokee Technical Forum 5 05-21-2008 09:08 PM
Transfer case shaft seal leak mollydodger XJ Cherokee Technical Forum 0 04-04-2006 07:58 PM
transfer case output shaft seal SuperStreetJeep XJ Cherokee Technical Forum 2 03-09-2006 08:44 PM
