Trailer wiring harness on the back of - JeepForum.com
post #1 of 35 Old 02-16-2011, 01:44 PM Thread Starter
maachuu
my 95 jeep cherokee country wouldnt work properly when connected to 4 pin connector for my boat ( turn signals worked, no tailights) pull the 7 way connector out of bumper and was trying to pull apart and check, well it was so corroded that I couldnt save to connector and it was so bad that when I got into it, it just fell apart. I have a new connector but cant seem to get it connected up right to work with my 4 pin. I have been able to get turn signals to work. I did see that when the plug came apart the green brown stripe wire was in the ground screw. As mentioned, this is a 7 way connector and I want to use a 4 pin connector (which I have the adapter for this). I dont have brakes on my trailer or reverse lights. tailights, brake and turn signal is all I have. Im sure the connector coming from the back of the jeep is some type of T connector but I dont know the wiring diagram for it
any and all help greatl appreciated
maachuu
maachuu is offline
post #2 of 35 Old 02-16-2011, 01:51 PM
Ben
Colors are available on this page:
http://www.etrailer.com/faq-wiring.aspx
You can't just wire the plug into the stock Cherokee wiring harness.
You need to combine the stop & left turn, and stop and right turn, but you can't just wire them, you need a box made for it.
It's because the Cherokee tail light has seperate stop and turn lamps, and the trailer uses the same lamp for both.
This piece is what you're missing:
Ben is offline
post #3 of 35 Old 02-16-2011, 02:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Just get a plug and play T style connector. Unclip the tailight wire harness, clip the T connector in, and you're done.
CJ7-Tim is offline
post #4 of 35 Old 02-16-2011, 02:29 PM Thread Starter
maachuu
I feel like it already has the part for combining of the wires, just cant figure out how to wire the 7 way back in
thanks
maachuu is offline
post #5 of 35 Old 02-16-2011, 02:42 PM
CJ7-Tim
CJ7-Tim's Avatar
If you can't figure it out, then your other option is to buy a new trailer light adapter specifically for your 95 Cherokee.
Take off the trim panel behind the spare tire, unplug the defective 7-wire connector, plug in the new 4 wire connector with combiner/adapter, and put the panel back on. Shouldn't take more than 15 minutes.
CJ7-Tim is offline
post #6 of 35 Old 02-16-2011, 03:41 PM Thread Starter
maachuu
Thanks Tim, looks like that is what I may have to do
maachuu is offline
post #7 of 35 Old 02-16-2011, 06:03 PM Thread Starter
maachuu
Tim, ben1 check these 2 out and tell me which one you think it would be, also why such a price difference ??
http://owensclassicinternational.com/hy42455-2.html
http://www.etrailer.com/Custom-Fit-V...cleid=19957433
thanks guys, I do appreciate it
Larry
maachuu is offline
post #8 of 35 Old 02-17-2011, 02:52 AM
CJ7-Tim
CJ7-Tim's Avatar
etrailer.com has a good reputation, I would get the part from them. The other place looks like they deal in surplus stuff. You can Google either part number listed and confirm the application and check the prices.
CJ7-Tim is offline
post #9 of 35 Old 02-17-2011, 06:47 AM
Ben
Yeah, I got my drawbar from etrailer too. Really, they look like the same part though. Etrailer has the best prices on the 2" reciever, maybe they need to makeup profit on the little stuff like that.
From what you're saying though, you don't need that. You just need to tie these wires in:
green: right turn
yellow: left turn
white: ground
brown: tail lights
so if your turns are working, and your brown is on a ground screw, I think that ground screw is the problem. I'd mess around with it a little more before buying anything...
Ben is offline
post #10 of 35 Old 02-17-2011, 09:00 AM Thread Starter
maachuu
thanks ben1
maachuu
maachuu is offline
post #11 of 35 Old 02-18-2011, 07:27 PM Thread Starter
maachuu
ok, got my new T connector for my model of jeep, after pulling the side panel and after thinking about it, I believe the previous owner said this jeep had the towing package. I found the connector coming out of the tail light and unplugged it and plugged the T connector in and nothing, I did notice that the connector coming out of the tail light appears the have addtional wires coming out of it to another connector, I believe it is probably the electric brakes and maybe a reverse light. Not sure how to connect the new connector up in order to make it work.anyone got any ideas ??
thanks
maachuu
maachuu is offline
post #12 of 35 Old 02-18-2011, 07:40 PM
hubs97xj
1997 XJ Cherokee
From the instructions:
1. Open rear door of vehicle.
Temporarily remove spare tire and
rear quarter panel trim located on
driver's side (Fig. 1).
2. Locate vehicle's tail light wiring
harness with black rectangular
connectors matching the ends of
the T-connector adapter (Fig. 2).
Separate the harness connectors,
being careful not to break the locking
tabs.
3. Insert the T-connector adapter
between the harness connectors and
lock into place. Be sure that connectors
are fully inserted with locking
tabs in place.
4. Reattach the rear quarter panel
trim and spare tire to their proper
positions.
5. Test the installation with a test
light or trailer.
This unit is rated for 4 amps per
circuit.
hubs97xj is offline
post #13 of 35 Old 02-18-2011, 07:56 PM Thread Starter
maachuu
tabs.
tabs in place.
positions.
light or trailer.
circuit.
thanks Hub, did that and had no turn signals or nothing, but it got dark on me , I will try again when I have more time
thanks for the write up tho
maachuu
maachuu is offline
post #14 of 35 Old 02-18-2011, 08:15 PM
hubs97xj
1997 XJ Cherokee
When you unplugged the taillight harness connection to plug the T in, you plugged both of the stock connectors into the T, right?
hubs97xj is offline
post #15 of 35 Old 02-18-2011, 09:04 PM Thread Starter
maachuu
been thinkin bout that, will have to check tomorrow, I do know that I had turn signal on the jeep but just not out the 4 pin connector, I will check more to more when I have more time
thanks
maachuu is offline
direction on installing trailer wiring harness xjpilot XJ Cherokee Technical Forum 5 07-11-2010 01:01 PM
Need Help With Trailer Wiring Harness Routing XJAl XJ Cherokee Technical Forum 1 03-22-2010 07:29 AM
Trailer wiring harness access plug/ mcthnif XJ Cherokee Technical Forum 4 12-30-2008 11:05 AM
Scored a Trailer Wiring Harness at Junk Yard for $0, need wiring diagram photonut13 XJ Cherokee Technical Forum 1 04-12-2008 01:39 PM
Help a newbie install trailer wiring harness... runwithscissors XJ Cherokee Technical Forum 2 10-14-2007 09:34 PM
