Trailer hitch bolts - JeepForum.com
post #1 of 7 Old 01-30-2008, 07:58 AM Thread Starter
Milemaker13
Trailer hitch bolts
I need to find bolts to attach my hitch to the frame. It only the light duty class1 reciever, but I still want it solid. Obviously I need carrage bolts so they will not spin in the slotted holes in the frame. What grade bolts do you think I need? Thanks!
Milemaker13 is offline
post #2 of 7 Old 01-30-2008, 08:04 AM
XJ2000
XJ2000's Avatar
Grade 8 are usually the best option.
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
post #3 of 7 Old 01-30-2008, 08:14 AM
Grand Fan 4eva
just something to consider, i got my class III hitch for free off a junked xj...
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #4 of 7 Old 01-30-2008, 08:51 AM Thread Starter
Milemaker13
Yeah, I got the class 1 off a junker too. But its what I have at the moment and it will do for now. When I find a class 3 that I can grab, the swap won't be tuff at all (as long as it isn't 5 yrs. from now!).
post #5 of 7 Old 01-30-2008, 10:07 PM
GhostSSX
GhostSSX's Avatar
Don't forget you need those sqaure washers with the square hole for the carriabge bolts that slide in the frame!
GHOST
1996 Green XJ Sport - Current Beater
GhostSSX is offline
post #6 of 7 Old 01-31-2008, 11:33 AM
sweenepj
Actually on the newer xj's I think the hitch bolts up into the frame in pre-tapped holes so you don't have to mess with threading those carriage bolts through the frame and the square plates. It's been a couple years since I put my hitch on my 99 xj, but I believe that's true... I know it was much easier than doing it on my 88 :-)
sweenepj is offline
post #7 of 7 Old 01-31-2008, 02:13 PM
Grand Fan 4eva
the factory nut strip is already installed on the passenger side of the 97+ xj's to hold the exhaust. the bolts are metric and from what i understand, automotive metric is stronger than grade 8 but don't quote me on that. the problem is that the nuts can rust out if there haven't been any bolts in them. when i did my hitch, i bought new nutstrips for each side from the dealer for 25. figured i got the hitch for free and the skid for 30 so it was still dirt cheap. made things super easy and definitely solid. wrestling the hitch and skid into place by myself was enough crap, i didn't want to mess with fishing bolts through although it probably wouldn't have been much more difficult. i just liked the idea of the strips, it's not going anywhere.
heres my class III install with a mini write-up:
http://jeepforum.com/forum/showthread.php?t=406483
'91 MJ
'68 M715
'98 5.9 Limited
Trailer Hitch element54 XJ Cherokee Technical Forum 0 09-26-2009 08:30 PM
What size bolts for trailer hitch 93ZJbeast XJ Cherokee Technical Forum 2 06-01-2009 08:03 PM
Trailer Hitch Rollin XJ Cherokee Technical Forum 6 09-30-2008 11:59 AM
trailer hitch se-real XJ Cherokee Technical Forum 4 12-18-2007 07:14 PM
trailer hitch crookedletterd XJ Cherokee Technical Forum 14 10-21-2002 03:45 PM
