Track Bar Relocation Mod - JeepForum.com
post #1 of 11 Old 07-24-2009, 04:06 AM Thread Starter
Baksidar
1997 XJ Cherokee
Ok so after much research into my forthcoming 4" lift,
I've decided to reuse the stock track bar but redrilling the mount 3/4 " inboard and upwards slightly as shown below
I will centralise the axle by having someone turn the steering wheel (with track bar disconnected) whilst i take measurements.
I then realised that the track bar will limit axle droop because contact will be made at point X as shown below !
So taking the dremel cut along the yellow line up and over the bracket as outlined.
Taking care to only trim the front and top of the bracket and leaving the bracket behind the track bar untouched ,it should now look like this.
The new edge of the original bracket is shown in yellow.
You can now see that the point of contact has shifted from point X to point Y
Much more clearance and best of all ITS FREE
Can anyone see any downsides to this mod ?
"Alcohol does not make you FAT - it makes you LEAN.... against tables,chairs,floors and walls"
Baksidar is offline
post #2 of 11 Old 07-24-2009, 04:30 AM
bobfortier
No downside I can think of. Which reminds me to go check my bracket to see if there is any contact...
edit. Thinking of it, I don't see how there can be contact, since the trackbar stays in the same plane as the axle tube when that side drops. And when the other side drops in is also not moving a lot. (someone correct me if I'm wrong...)
Bob in Thetford Mines, Province of Québec
bobfortier is offline
post #3 of 11 Old 07-24-2009, 06:05 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The stock trac-bar is still gonna limit your flex, on the frame side the tierod end will only travel so far and then it will bind. At stock height it is sufficient enough, but at the new height it is already pulled toward the end of it's range. It will work the way you have it, but it will limit flex.
xjfever is offline
post #4 of 11 Old 07-24-2009, 09:14 AM
justanotherjpr
It wont drive as well or flex as well as it could with a good after market bar, but it will work.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #5 of 11 Old 07-24-2009, 09:35 AM Thread Starter
Baksidar
1997 XJ Cherokee
I was thinking more of when the whole axle drops (as happens when you install longer springs) not just one side.
Baksidar is offline
post #6 of 11 Old 07-24-2009, 10:45 AM
srmitchell
While it's a great budget mod, you aren't helping your flex.
Most aftermarket track bars have some type of high angle joint at the frame, allowing more articulation.
I work on Mopars
srmitchell is offline
post #7 of 11 Old 07-25-2009, 03:39 AM Thread Starter
Baksidar
1997 XJ Cherokee
Yeah thats exactly what i'm saying its a great budget mod for upto 4" - 5" lift.
But are there any downsides apart from saving money
Baksidar is offline
post #8 of 11 Old 07-25-2009, 04:15 AM
sprintagogo
I am using the stock track bar with 4" of lift and even when I lower the axle untill it is hanging by the shocks the trackbar can still be unbolted from the axle and lowered a further 1½"-2" so it is still not at the limit but not far off.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #9 of 11 Old 07-25-2009, 05:27 AM Thread Starter
Baksidar
1997 XJ Cherokee
Oi Sprinty get your butt back to difflock
Only joking mate
When you've got your axle hanging by the shocks, how much clearance have you got between the track rod and the original bracket as shown at point X in the second photo ?
Did you redrill your bracket ?
Oh and whats the weather doing up in Ashton cos i've got family in Hyde and thats only 50 mins from me in Cheshire.
Baksidar is offline
post #10 of 11 Old 07-25-2009, 12:47 PM
sprintagogo
Only joking mate
Yes, I have redrilled the bracket (actually done it about four or five times as I have been through a few front axles but that is another story!) but I have no idea how much clearance there is. Lets just say it is enough as I can get the track bar bolt out and back in again when the axle is at maximum drop.
Is your vehicle a left hand drive or have you flipped the photo so our American cousins don't get confused?
The weather in Ashton has been great today which is a big help as I have all the Jeep windows open to let the carpets dry after a little dip in the fine Tong water last weekend.
Rollin on 32'zzzz
Who's eric?
post #11 of 11 Old 07-26-2009, 03:38 AM Thread Starter
Baksidar
1997 XJ Cherokee
Well spotted sir.
The photos are of a lefty as i didn't want any confusion and mines a righty
If you look again at the first photo,in the bottom right is the date,if the photo was flipped then the date would also be flipped
Baksidar is offline
track bar relocation bracket 1996jeepxj XJ/MJ Cherokee Non-Technical Forum 1 03-24-2009 07:03 PM
Should I use an extended track-bar bracket with an adjustable track-bar? Magickman XJ Cherokee Technical Forum 10 08-23-2008 11:12 PM
dumb idiots: adjustable track bar/HD track bar mount writeup sharpie XJ Cherokee Technical Forum 11 05-06-2007 09:52 AM
Track Bar Bracket/ OEM Track Bar ?? 3" Lift Mikepags XJ Cherokee Technical Forum 5 06-08-2006 04:22 PM
NEED track bar relocation bracket 85jeepinwyo XJ Cherokee Technical Forum 4 03-02-2004 07:53 AM
