Track Bar axle bolt - JeepForum.com
post #1 of 16 Old 12-16-2011, 02:34 PM Thread Starter
90xjlimited
1990 XJ Cherokee
Track Bar axle bolt
Installed RC's adjustable track bar today. The axle mount limits access to the interior side of the bolt, where the nut is. Do you guys have any ideas how to clamp down on the nut so I can torque the bolt down properly. I can barely get anything in there.
Also, the track bar slides left and right as the wheels turn. I can see the axle mount bolt jump around. I'm not sure if once I get it torqued down that it would be enough to keep it still. I'm afraid the hole is a bit wallowed. But, I don't want to drill a new hole and weaken the axle mount either.
90 XJ-RC 3 in. Series II-31x10.5 Grabber AT2's-Soft 8's-Leigh's 60mm TB-K&N Rusty's tube-5.0 injectors
90xjlimited is offline
post #2 of 16 Old 12-16-2011, 02:37 PM
XtrailratedJ
That track bar bolt needs to be TIGHT. There is a slot where you can fit an open ended wrench in flat then turn it vertical to hold the nut while you tighten the nut.
I just installed a RE Adjustable Track Bar on Wednesday.
96 XJ 4.0L/AX15/NP231/AUSSIE'D D30/C8.25/4.5" RE LIFT/33'S/BUMPERS, SLIDERS, ETC...
"I pitty the fool who lists D30's and 31's, then tries to talk **** on PBB":
Originally Posted by Durt_Diver:
Those pics might be a little too flexy for this thread. You don't happen to have any pics of your friends xj on a curb by chance?
XtrailratedJ is offline
post #3 of 16 Old 12-16-2011, 05:25 PM
theshaolin
I reused the stock flag nut without issue. If it's loose, I'd get a small plate, drill the proper sized hole in it, and weld it to the axle over the original hole.
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline
post #4 of 16 Old 12-16-2011, 05:31 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I always use a cold chisel or better yet, a tapered punch. Slide it into the red circle, parallel to the ground, and you can usually wedge it between the bracket and a flat on the nut. Once wedged in there the nut will not turn.
I have never had any luck getting a wrench in there.
CJ7-Tim is offline
post #5 of 16 Old 12-16-2011, 05:52 PM Thread Starter
90xjlimited
1990 XJ Cherokee
Thanks for the replies, guys. The stock nut is 11/16 and there was no way I was getting a good bite in there. I just put two washers behind the nut. That moved the nut into a position that I could grab from the side access point. I took out all of my frustration into torquing that sucker down.
Where's the Tylenol?
post #6 of 16 Old 12-16-2011, 06:23 PM
rugsucka
The stock nut is NOT SAE - it is a 12mm metric.
If you use a SAE fastener you can wallow out the hole and encourage DW.
I used the wedge a screwdriver in there trick when I put the IRO double shear set up about a month ago.
rugsucka is offline
post #7 of 16 Old 12-16-2011, 09:30 PM
egodfrey
egodfrey's Avatar
I like tim have used a pry bar and just reached in there and pryed on the nut jammign it while i tighten
I never torque it, just make it real tight and your fine.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #8 of 16 Old 12-16-2011, 09:41 PM
EricsXJ
The Post man
EricsXJ's Avatar
If the hole is wallowed which by your description sounds as if it is, then you will be fighting a losing battle with that bolt. You will not be able to keep it torqued tight enough to prevent the bolt from moving, or you risk breaking the bolt by putting too much torque on it.
When you get the chance fix the hole by welding a thick washer over the face of the bracket, creating a new hole with zero play with the bolt. Or weld a plate on it and drill a new hole.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #9 of 16 Old 12-16-2011, 11:30 PM Thread Starter
90xjlimited
1990 XJ Cherokee
No way the bolt that came on my XJ is 12mm. The bolt end is 15mm. I took the nut off and matched it to whatever I had that would grab it. If it's metric, it's more like 17mm or 18mm, 11/16 grabbed it pretty tight. My Jeep is a '90. Anything could have happened to it during the 19+ years I didn't know her.
I've got it torqued down well with the washers in place.
Thanks for the advice!
post #10 of 16 Old 12-17-2011, 12:07 AM
sAe23
1995 XJ Cherokee
What length did you adjust it to, and did you have to remove the jam nut to get it short enough??
sAe23 is offline
post #11 of 16 Old 12-17-2011, 01:37 AM
234hawgbelly
2003 WJ
rugsucka is talking about the bolt diameter: 12mm, very close to a 1/2 inch SAE bolt.n The head of the bolt is 15mm hex and the nut (the one difficult to get to) is an 18mm hex nut, that's what I have in my 96 XJ
234hawgbelly is offline
post #12 of 16 Old 12-17-2011, 08:31 PM Thread Starter
90xjlimited
1990 XJ Cherokee
I have no idea what length it is. The jam nut is in place, nowhere near where I would think about remove it to fit the bar.
post #13 of 16 Old 12-17-2011, 08:38 PM Thread Starter
90xjlimited
1990 XJ Cherokee
I thought rugsucka was referring to the bolt diameter. Those bolt/nut sizes are exactly what I have on the '90. 11/16th is real close to 18mm.
It took me 10 minutes to swap out the bars and about 2 hours of trying to get that one bolt snug.
On to something else that needs to be replaced............
post #14 of 16 Old 12-17-2011, 09:20 PM
DoctorTim
i welded a piece of 1/2" wide flat bar onto the nut and bent it so that it would stop on the small opening right under the mounting bolt. worked great.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #15 of 16 Old 12-17-2011, 10:43 PM
BriansCJ
1994 XJ Cherokee
I got a new bolt/washers and lock nut. I managed to put the nut on finger tight, then put a 17mm box end wrench in there and got it over the nut. I used a regular craftsman wrench, I tried a different one and it didnt work. Also, if the bolt is too long, you might not be able to get the wrench out.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
Getting track bar bolt out ksander XJ Cherokee Technical Forum 9 12-11-2008 01:56 AM
Track Bar Bolt Head Axle End Sheared Razor. XJ Cherokee Technical Forum 6 11-10-2008 08:25 PM
track bar axle mount bolt specs in_motion XJ Cherokee Technical Forum 3 10-16-2007 09:51 PM
Track Bar Bolt, how to get out? 89xjsteveo XJ Cherokee Technical Forum 16 01-08-2007 05:30 PM
Track Bar Axle Bolt-hole Fix Robs92XJ XJ Cherokee Technical Forum 3 10-09-2006 11:56 PM
