Trac-Lok identification - JeepForum.com
post #1 of 5 Old 01-17-2006, 11:42 PM Thread Starter
quafiediff
In my local junkyard there is an 86 wagoneer that I belive has a factory Trac-lok rear axle. I want to know for sure if it is so i can put it in my 87 Cherokee. Can anybody tell me a good way to check without taking it apart? Also, how well do these work, would it be worth it and does it bolt right up?
'87 Cherokee Laredo, 4x4, 4.0L, BA10/5, bone stock.
'71 Karmann Ghia convertible. 1915 cc,
128 hp @5800rpm, 28 MPG
'73 VW Super Beetle, bone stock.
quafiediff is offline
post #2 of 5 Old 01-17-2006, 11:50 PM
cherokeevince12
Mine has a positrack and there is a sticker in the glove department, a silver warning sticker that informs the owner the car has posictrac.
97 Cherokee 74k. 3" rustys with 32X11.5R15's BFG AT's. And one large hole in my dash where a stereo would be. ;) stupid thieves.
cherokeevince12 is offline
post #3 of 5 Old 01-18-2006, 08:17 AM
Chip S.
You don't need to take the whole thing apart, just pull the cover and look for some little clutch disks on either side of the carrier. I wouldn't trust the stickers or tags, the carrier may not be the original.
89 XJ Bored .040 over, ported, port-matched header, high-flow cat-back, 3"lift, MSD 6A, blaster coil, 4 wheel disks, relocated IAC sensor to K&N tube, triple core rad, NP231, AW4, PORC SYE, 225K mi Original owner.
86 Ford F-150 4x4 300 bored .040 over, decked and head milled .010, ported and port matched Clifford header, Comp RV cam, Offenhauser DP manifold, Holley 4160 600cfm, MSD Blaster coil, 2.5" exhaust out the side, BFG 31's.
My other Cherokee is an airplane
Chip S. is offline
post #4 of 5 Old 01-18-2006, 07:08 PM
Aquit45
Aquit45's Avatar
1990 XJ Cherokee
Just turn one side of the axle and if it turns the same way on the other side its the trac lock.
1990 Jeep Cherokee Laredo
One owner Only had 70,000miles
Aquit45 is offline
post #5 of 5 Old 01-18-2006, 08:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Trac Loc is a limited slip differential. It works better than an open diff, but not as good as a locker. The clutches wear out, but they can be rebuilt. If you don't need a replacement for your current axle go with a Lock Right or Aussie Locker. Most, if not all, XJ axles will exchange from year to year.
CJ7-Tim is offline
trac bar drop VS. trac bar relocation bracket iwishihad1 XJ Cherokee Technical Forum 6 12-21-2011 01:02 PM
Select-a-trac axle with Command-trac Transfer case (how do I do my allignment?) CharlieMopps XJ Cherokee Technical Forum 7 11-05-2008 03:21 PM
Command Trac vs Select Trac? Xtnct00WS6 XJ Cherokee Technical Forum 1 12-18-2006 10:08 AM
Convert command trac to select trac???? grasshopper XJ Cherokee Technical Forum 15 12-11-2005 11:51 AM
