trac bar - Page 2 - JeepForum.com
post #16 of 29 Old 10-21-2013, 03:20 PM
biffgnar
biffgnar's Avatar
Originally Posted by cbenez1 View Post
No one ever said removing the trac bar was good for ride on any year, make or model Jeep.
I was under the impression that YJs and CJs while being leaf sprung front and rear came with track (or panhard) bars. Removal of them is very common on those vehicles I believe and safe given the leaf spring setup.
Romney in 2020!
biffgnar is offline
post #17 of 29 Old 10-21-2013, 09:35 PM
cbenez1
You may be right Biffgnar. I don't remember my 86 CJ or 88 wrangler having one but they were both second hand so that doesn't mean it wasn't removed before my owning them. But looking at the front suspension/steering on an XJ and not seeing a problem with removing a trac bar shows a lack of knowing what your doing and subsequently claiming you did it because you were "duped"and "misinformed" by internet posts shows an even bigger lack of responsibility. I know this is hard to believe but I'm really NOT trying to bash the OP but rather stressing the importance of having a little mechanical knowledge/common sense when messing with your vehicle.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #18 of 29 Old 10-22-2013, 02:29 AM Thread Starter
xj89can
1989 XJ Cherokee
wow, ok ill find the links and post them.
im no idiot but thanks for implying it
id like to add that the post was intended as a warning to others who could also be miss lead.
its not like i read a single blurp, ran out blind folded and started ripping **** apart!
swaybars ok ...rear trac ok.... oh but dont touch the front!!! hmmmm ok im no genius but i see room for error here.
thanks for all your information and insults . i sure hope i can feed some of you a little crow .
happy trails
xj89can is offline
post #19 of 29 Old 10-22-2013, 02:49 AM Thread Starter
xj89can
1989 XJ Cherokee
xj89can is offline
post #20 of 29 Old 10-22-2013, 02:55 AM Thread Starter
xj89can
1989 XJ Cherokee
http://www.wranglerboard.com/f9/why-...ung-axles-237/
two, sure its wrangler..but its jeep! and its out there!!!
xj89can is offline
post #21 of 29 Old 10-22-2013, 02:56 AM Thread Starter
xj89can
1989 XJ Cherokee
mmmm crow
xj89can is offline
post #22 of 29 Old 10-22-2013, 03:34 AM
westy2005
Both of those are wrangler forums. More specifically YJ forums. Funny thing is that within the first couple posts, it shows a picture of LEAF SPRING suspension.
You're right, it is in fact a Jeep. Where you were wrong is that you ASSUMED they were the same. Guess your "crow" bit you on this one. Take this advice from everyone that has responded so far, put down the wrenches, and pick up a book and educate yourself before you go out and hurt someone.
1999 XJ, 4.0, AX15, 33x12.50's, Winch....Still learning the capabilities of this thing!
westy2005 is offline
post #23 of 29 Old 10-22-2013, 04:17 AM
Shadownwpa
... did you think those curly things holding your front end up were called leaf springs?
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #24 of 29 Old 10-22-2013, 07:24 AM
cbenez1
Originally Posted by xj89can View Post
mmmm crow
No where did I imply that you were an idiot. What I am stressing is your lack of experience with this particular subject. I have no experience flying a commercial airliner so I would not jump in the cockpit and start hitting switches during a flight. I am experienced with Jeeps but my wife drives an Xterra and I don't mess with it because I have little knowledge of it. Are you seeing the pattern here ? Not knowing about 1 particular make & model of vehicle does not make you dumb but making a mistake and blaming an internet post that you misread might. My point was to be more careful. Just to be clear; INEXPERIENCE IS NOT LACK OF INTELLIGENCE !!! Don't be insulted by it. Learn from it. Oh and open your mouth cause I think that crow just made a U-turn and is heading your way.
cbenez1 is offline
post #25 of 29 Old 10-22-2013, 08:20 AM
grandboost98
He more than likely came across a YJ thread, we dont run front or rear track or sway bars.
As stated, a track bar is a must with coil suspension
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #26 of 29 Old 10-22-2013, 12:13 PM Thread Starter
xj89can
1989 XJ Cherokee
its a easy mistake !! is my point gentlemen if its not clear
xj89can is offline
post #27 of 29 Old 10-22-2013, 12:20 PM
westy2005
Shouldn't even be a thought on an xj. Is our point. Know what you're doing before you hurt yourself, or god forbid, someone else!
post #28 of 29 Old 10-22-2013, 01:09 PM
biffgnar
biffgnar's Avatar
No, it's not. That is everyone else's point if its not clear.
Difference between a YJ and XJ and the difference between leaf springs and coil springs are pretty fundamental things to consider when making changes to your jeep.
Romney in 2020!
biffgnar is offline
post #29 of 29 Old 10-22-2013, 01:17 PM
cbenez1
Yeah that's kinda what we figured. Thanks for confirming it with YJ's. Like I said before I had 2 wranglers in between XJ's and neither had a trac bar. I figure they were removed prior to my owning them.
cbenez1 is offline
