#1 | |
TPS or bad injector
hey. after running through my jeep i think i have narrowed my problems to either a bad injector or a improperly adjusted TPS.
I tested my TPS using the FSM directions involving checking two voltages and comparing them to get a ratio. they say i should come out with .83 or 83%. well, i came out with .8237 or 82%. Is that one percentage point enough to make the motor buck like its backfiring, and have a pretty bad skip somewhere in mid-throttle. it sounds alright at idle, and when i press on the gas to go, if i stay in that spot where you keep the pedal to maintain speed when you're cruising (just down a little bit) thats where it does bad nowhere else
1987 Comanche 4x2 (broken down, stolen, returned with some stuff fixed and other stuff missing/broken, DOA, scrapyard in sight) 1989 Cherokee Limited 4x4 |
#2 |
0.8% off is fine, thats pretty much within a test instruments margin of error.
but it does sound like theres a dead spot on it. Im not sure how the fsm tells you to test it but if its just hooking an ohm or volt meter up to it make sure its smooth over the whole range of travel and doesnt jump around. it should gradually change with with throttle position with no jumpiness or dead spots. analog meters may be better at seeing that.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling [COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street |
#3 |
In the various 4.0`s Ive had TPS settings prior to adjusting have been anywhere from .7 to .95, after adjusting them I didnt even notice any difference, still ran great. I cant see that be the cause of your issues.
#4 | |
#5 |
well, i might end up replacing it, but right now i have a problem that needs to be addressed before i can even fix that.
i took the intake hose off the throttle body and found another problem. my butterfly valve is sticking... its like it wont stay centered and the play it has is letting the valve stick on the firewall side of the opening at the center it has a scrape that when i hold the valve up, means that the valve is scraping from close to 1/3 or a little more throttle. scraping and possibly sticking. anyone know what to do with this without taking the throttle body off? i lack torx bits big enough
#6 |
yeah, and i have checked the TPS with an analog meter, and it does move smoothly. i tried moving it pretty slow, and it looked good.
#7 |
Id of bet money that the TPS has a bad spot. I would double check that the voltage (or resistance) is smooth over its range paying particular attention to the throttle position that causes the stutter. it could be smooth over 99% of its travel with only a smallish glitch on the bad spot. thats all it would need to mislead the computer.
as for the butterfly valve sticking you would definitely know if it actually sticking as its mechanically linked to your gas pedal and it would stick in position too. its a pretty strong spring so personally I wouldnt worry about it if the scrape looks very minor unless it seems like its really sticking bad, but thats just me. has it ever actually stuck or caught? engine always drops right to idle when your foot is off the gas? can you post a picture of the scrape?
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling [COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street Last edited by CharBroiled; 09-16-2007 at 12:13 PM.. |
#8 |
yeah, it was definitely sticking. when i had the motor running, it would not always drop down to idle, and i checked the mechanical linkage and sure enough the stop plate was falling to about 3/16 to 1/4 inch away from the set screw. so i opened it up, sprayed everything down with carb cleaner and worked it in really good
it seemed like its fixed it for now. ill take it out for a drive in a bit to see if anythings better. right now im trying to get the drivers side of the axle shifted forward by means of moving that control arm behind the tire that goes to the axle. im hoping that will stop my front driveshaft from knocking on my exhaust
#9 | |
#10 |
yeah... i was trying to do everything to avoid something more than 10 bucks, but i guess it can't be helped.
i rode it around the block after my latest series of adjustments, and it improved, though not as much as i had hoped. its still stumbling, and it had a few backfires, though not as many. so i took it for a ride with the TPS unplugged. It rode smoother if anything. only one backfire, and about the same amount of stumbling. i reckon this means my TPS is bad, right? thanks for all the help so far
#11 |
sounds like the same situation i dealt with when i had a bad tps. its only like 25 dollars tho, no big thing.
#12 | |
#13 |
oh i suppose it is a 89, it would be renix huh. sorry.
#14 |
$250 Mechanic bill for new alternator install. problem not solved.
So i the mechanic insisted that he change the alternator thinking that it was the reason for the squeak/knocking sound.
Well, it wasn't the problem, it still knocks and I'm stuck with a $250 bill and a louder diesel sound knock. And its not the serpentine belt, changed it three times. I still think its the rocker arms. Thanks |
#15 |
so i have now replaced the TPS.
no change changed an injector that was giving me problems. the new one is a GP Sorensen from autozone. now i have a high idle. i crank the truck up and it just sits there at 1500, and it still skips when i rev it but, never say die. anybody got a clue why after changing the injector i would have a problem like this?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
