#1 | |
Toyota axle in an xj?
I guess they are 30 spline, 8" ring gear, and my friend ran 36" swampers with no problems. He wants to sell one stuffed w/ 4.88's and a detroit for $500. Are these toyota rear axles really that strong? Anyone know the wms-wms? Bolt pattern? Another plus, IMO, is the third member.... I have never seen this done before, is there somethign wrong with it...?
I did do a search, but this is all i found so far.... http://jeepforum.com/forum/showthread.php?t=100865&highlight=toyota+axle
[B][COLOR=DarkRed][COLOR=DarkRed][B]93 xj 211,000 miles rusty's 4.5" lift aa sye tw cv ds ford 8.8 w/ 4.10 gears and an aussie locker 4.10 gears front 15x8 rockcrawlers w/ 3.75 bs 33x12.5 radial tsl's no swaybars[/B][/COLOR] Got her back![/COLOR][/B] [COLOR=Yellow]http://www.freeiPods.com/?r=17745586 free ipod[/COLOR] [COLOR=Yellow]http://www.geocities.com/campo4x4/Campolindo_4x4club.html[/COLOR] |
#2 |
Little Red Menace
This was a hot topic on NAXJA.org and the general consensus was it's a good swap. I think it's the SR5 that has the same bolt pattern as well as a VERY close WMS size. Only a tad bit more difficult to adapt the DS, but not enough to make it a bad swap.
Yeah, the axles are pretty damn stout.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
When they are properly trussed they are just about as stout as you can get from a factory axle. Also parts are relatively cheap, so before they catch on buy it. Think about this, You cant regear, and lock any axle for 500, so that would make it worth it to me.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it [url]http://independent4x.com/generic67.html[/url] [url]http://community.webshots.com/user/cj7xjmj[/url] If you have to ask why... Its a truggy thing and you wouldn't understand |
#4 |
a ton of people around here with tacoma SR5's are running 35's and up with no problems. I'd say do it! and if you don't want to deal with all that fabbing, give it to me
stock 2000 Cherokee Sport black 4 dr. |
#5 |
the toyota axles are stout stout little things. i would go for it because like said before you couldnt do that to your axle and hold up big tires for $500
1990 Jeep Comanche Pioneer 4x4 4.0L - D30/D35 - 5-Speed - NP231- 130K 1998 Jeep Cherokee Classic 4x4 4.0L - D30/Corp 8.25 LSD - NV242 From a 2002 Grand Cherokee - 4" Suspension/31's - 136K |
#6 |
On several wheeling trips with yotas and Jeeps my XJ has had to represent for Jeep after the so called "real Jeeps " choked . There's no way I'd give them the satisfaction of seeing a yota axle under my Jeep. There's to many other good options available.
#7 |
As for "real jeeps" choking, whats that mean? Personally I run a ford 8.8 now, and a severely modded d30 upfront, but if I could find an axle that was a easy swap in for the front that didnt require a huge chunk of money, or lots of fab work to make it work, I would have done that instead of building my D30.
It all goes back to one of the lines in my sig, real jeeps are Built .. not Bought, and Its not what you break it is how fast you fix it. Patrick
#8 | |
Little Red Menace
#9 | |
Silver Jeep Club Member # 829.3 6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :) |
#10 | |
#11 |
Little Red Menace
Yep, C-clip elemenators. Couple of different manufacturers make them for the 8.8. Check summitracing.com for some.
#12 | |
#13 |
OH those real Jeep owners. I just dare them, to follow me and take the lines I take
LWB vehicles rock on off camber and long climbs I have it wosre then you XJ owners, I am a MJ, I have been accused of being a foreingn truck Aas far as c=clips go, and having to dismantle a locker on the trail. I have personal experience with both c-clip and non-clip axles. If you break a c-clip axle, all you have to do is just swap axles (carry spares), as for non c-clips, it is pretty much the same thng, but you have to make sure your spare have good bearings on them, and that they are relatively dirt free. You also have to remove 4 PITA nuts and bolts, that are hard to get to. Luckily, If you have a 96 or newer 8.8 the axle will stay in place cause of the disc brakes. Also under modraste wheeling you probrably never will break an 8.8. Warn did some testing on the axle shafts, and they could not break them with that machine. So they went to the next one, and they estimate the strength to be within 500 ftlbs of the D60 axle shafts. Irregardless of that, it is far stronger then a D44, and I wont even discuss the d35. Patrick
#14 | |
Remove 4 bolts....slide the shaft out.....then slide a new shaft back in, then tighten up the 4 bolts? Unless i am missing something it seems a LOT easier to replace a broken axle on a non-clip axle.
#15 | |
YJ->donated; XJ->donated; XJ->in progress. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
